Bug stuck in 08 Civic's odometer. How can I get it out?
Rep Power: 0 Bug stuck in 08 Civic's odometer. How can I get it out?
I have no idea how it got in there, but it's very annoying. I'm hoping that the solution is simple and doesn't require much (if any) disassembly. Thanks!
over 100 one hit ko's on the block
Rep Power: 0 Re: Bug stuck in 08 Civic's odometer. How can I get it out?
everything comes apart, how do you think it got together? youtube ul prolly have a video to show you how to open her without damaging
Haha now ill actually help.....http://www.8thcivic.com/forums/audio...nstall-ex.html
You will definitely have to disassemble the dash to get it out, Follow the steps up until the point where the cluster is exposed. Unscrew the screws for the cluster and pull it out. After this you're on your own, im not sure if you can open up the plastic but maybe you can find a hole that the bug will fall thorugh or you can just shake it into the corner where its harder to see if nothing else lol.
C2i0v0i1C
11-14-2001 10:46 PM
