07 lx coupe reverse noises on inclines
Rep Power: 0 07 lx coupe reverse noises on inclines
So for a while my car had been having this weird noise when I go into reverse from park without turning the car off completely. This usually happens At my friends house because of his driveways leveling. I usually park on the street along the curb regardless, but I've noticed it's more likely to do it without the e-break on. Mind you these are quick stops. So I'll usually have to e-break it with the car still on. Now as for the noise: it doesn't sound like it shifts right. I can feel it shift and it's rugged and makes a loud shuttering noise. I can also feel a quick vibration from shifting as I hit reverse. Is this just transmission problems?
Rep Power: 787 Re: 07 lx coupe reverse noises on inclines
when you park on an incline, you must use the e-brake to hold the car BEFORE putting the car in park and letting go of the brake pedal. when leaving, you must press the brake pedal and shift into gear BEFORE releasing the e-brake. you should never have any problem if you remember this. basically when you dont use the ebrake, you are putting the load of the car onto the transmission, and this can be very bad over time. by using the ebrake, you are putting the load onto the rear brakes instead and saving your trans.
yeah for example, after you stopped with your foot on the brake and car in drive, before you do anything pull up the ebrake. then shift to P, then let go of the brake pedal. when you get ready to leave, start car and press brake pedal, then shift to R or D, then finally lower the ebrake and then let go of the brake pedal to get the car moving.
Blazz
06-04-2015 01:04 AM
Russps
11-08-2001 02:00 AM
