Regular Maintenance Post Questions/Information about Regular Maintenance here
When should I change the fuel filter and spark plugs?
Old 05-04-2012
torontob's Avatar
torontob is an unknown quantity at this point
Hello everyone,
Spark plugs seem to be fun to change and my Civic 2009 DX-G has 105k km on it so it's probably time I should change those but I never done it.
Also, Grees & Ross told me they want to change Fuel Filter. I told them I have to consult civicforums first before I pay you a penny for it. I have never changed a fuel filter and don't know what it is.
Please guide as to how easy it is to change the fuel filter or if I need to change it? Also, same for spark plugs.
Car runs well and no problems.
Thanks
Old 05-04-2012
99civic360's Avatar
99civic360 is an unknown quantity at this point
Re: When should I change the fuel filter and spark plugs?
For your spark plugs it should tell you in your owners manual when to change them, and or if you are having troube starting and notice a decrease in power will trying to accelerate. on the fuel filter, i'm not sure when you are suppost to change them but it is keeping the water and sediment from reaching your engine. so if it needs changed it also might feel like your engine isnt getting enough fuel sence the filter is full. i'm not an expert but i have heard. going to be doing it to my civic soon also. good luck.
Old 05-04-2012
Prelude Owner
GolNat's Avatar
I do my plugs every 30k miles cause there cheap and keeps mpg up. I need to do my fuel filter also. I think 30k is suggested for fuel filter. If you use high quality gas then you could go longer. Spark plugs you can change yourself, not sure about fuel filter for your civic.
Old 05-04-2012
RTFM (https://www.civicforums.com/forums/f...faq#faq_gen_q3)
Learn what the MAINTENANCE MINDER is and how it works.
Learn it, live it, love it.
The plugs are Iridium type.
Not cheap.
They are 100,000 MILE plugs, or 160,000 KM.
They can really outlast the car as long as they don't foul out.
RTFM
The fuel filter is not part of any regular service on that car. It is not serviced unless it becomes necessary (becomes a problem).
It is inside the fuel tank, part of the pump module.
It is something REAL EASY to SCAM you on, because YOU WILL NEVER EVER KNOW if the service was actually performed.
Again: RTFM
Is there a serious problem with the way the car runs?
Is the CEL onwith any codes that could possibly be related to either of your questions?
I'm guessing NO.
You need to locate a more reputable and honest shop. Preferably one that employs people that can fix more than a sammich.
HTH
Old 05-04-2012
torontob's Avatar
Thanks ezone.
That's what I thought about the fuel filter. Yep, there are no issues with the car and I am going to tell them to bug off.
Best
Old 06-22-2012
oscar11487's Avatar
oscar11487 is an unknown quantity at this point
ok i have a 2007 civic ex coupe car turns off when i stop and when i accelerate rapidly same thing even quickel on d3 is a auto tranny car will take almost a minute for me to be able to turn it on could it be spark plug ?service sensor do go on no othe sencor is on.CAR DO LOOSE POWER
Old 06-22-2012
No.
See why the Check Engine Light is on. Sound like it SHOULD be on if it runs that bad.
HTH
Old 06-23-2012
oscar11487's Avatar
i have no check engine light only the battery sensor and service light seen to me the altenator is not giving the battery enough power. or could be fuel filter not sure..
Old 06-23-2012
oscar11487's Avatar
no check engine light is on
Old 06-23-2012
the battery sensor .....
seen to me the altenator is not giving the battery enough power. .
Having a difficult time understanding exactly what your problem is.
When you said it loses power in the earlier post, you meant electrical power?
This is lit up?
Sounds like the alternator not charging (for whatever reason) is the biggest problem then. Fix that problem first.
May need an alternator, may be something else like wires or fuse.
HTH
Old 06-23-2012
oscar11487's Avatar
sorry about that bro but yes. that the sign i keep seing on my car
Old 06-23-2012
oscar11487's Avatar
yes is electrical
Old 06-23-2012
Fix that first.
Old 06-23-2012
oscar11487's Avatar
thanks you one last question will altenator need replace on a 07 ex coupe with only 32k?
Old 06-23-2012
Only a bad alternator would need replaced.
Why would a smart person replace a good one?
Is yours bad? I have no way of answering that from where I sit.
(32k seems quite premature, but I've seen all sorts of problems over the years.)
Many other things could be wrong that cause the exact same symptom.
Test, don't guess.
Old 07-02-2012
oscar11487's Avatar
hey bro so far altenator, fuse spark plug and batteries are good. i took the car to a mechanic who works on electricity since the problem is electrical what else could cause it too loose elctricity? no codes are own in the car
Old 07-02-2012
oscar11487's Avatar
could it be a faulty coil if it is how much will thta work cause me ?
Old 07-02-2012
For this light here?:
Absolutely not.
Quit guessing.
There must be a logical process to diagnosing it. Guesses aren't part of it.
You probably should just take it to a dealer.
Old 07-02-2012
oscar11487's Avatar
i got that issue fix it was a camb the was missing nt ssure wat was it called.. but i fix the problem it was a bad wire from fuel pump that stopped the car from pumping gas which made it hard to fine beacause fuel filter was fine
thana
06-15-2020 07:05 PM
mistermenphis22
04-03-2016 08:06 AM
dpru
05-26-2015 07:01 PM
Ninetyatecivic
05-09-2015 07:48 PM
Gunner
Engine DIY
10-06-2012 12:37 PM
Quick Reply: When should I change the fuel filter and spark plugs?
