Go Back   Honda Civic Forum > Honda Civics by Generation > 8th & 9th Gen > Mechanical Problems/Vehicle Issues and Fix-it Forum
Register Forgot Password?
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools Search this Thread
Old 02-01-2012   #1 (permalink)
Points: 42, Level: 1
Points: 42, Level: 1 Points: 42, Level: 1 Points: 42, Level: 1
Level up: 84%, 8 Points needed
Level up: 84% Level up: 84% Level up: 84%
Activity: 4.7%
Activity: 4.7% Activity: 4.7% Activity: 4.7%
steelfan95 is an unknown quantity at this point
2006 Civic EX - AC Fan Stopped Blowing Air
Weird thing happened to me today. I got in my car after work, turned on the AC (Florida) and nothing happened. No air, no sounds, nothing. I stopped to get gas and when I started the car the air was back on as if nothing ever happened??
Do you think the blower is starting to go? I also thought about the transistor, but figured if that went the air would not start blowing again.
Any ideas?
Thanks
steelfan95 is offline   Reply With Quote
Old 02-01-2012   #2 (permalink)
Should Plastic Jesus watch the road or watch me?
Location: Standing at the corner of WALK and DON'T WALK
Points: 13,771, Level: 76
Points: 13,771, Level: 76 Points: 13,771, Level: 76 Points: 13,771, Level: 76
Level up: 31%, 279 Points needed
Level up: 31% Level up: 31% Level up: 31%
Activity: 99.9%
Activity: 99.9% Activity: 99.9% Activity: 99.9%
ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of
LOL #youcantbeserious OMGWTFBBQ Seriously? I'm not 12.
Re: 2006 Civic EX - AC Fan Stopped Blowing Air
Needs a blower motor.
When it stops again, knock on it and see if it starts working. Under the glovebox. If it starts working, it needs a blower.
ezone is offline   Reply With Quote
Old 02-02-2012   #3 (permalink)
25 Years Japanese Autos
CraigW's Avatar
Points: 15,688, Level: 80
Points: 15,688, Level: 80 Points: 15,688, Level: 80 Points: 15,688, Level: 80
Level up: 68%, 162 Points needed
Level up: 68% Level up: 68% Level up: 68%
Activity: 27.9%
Activity: 27.9% Activity: 27.9% Activity: 27.9%
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Those blowers have been known to be intermittent.
The part # for them has been changed.
If/when it stops again, lower the glovebox and remove the cabin filter. You will be able to see the round white fan inside, with car on and blower at minimum speed reach in and spin the blades and see if it starts running.
Replacement is pretty simple.
CraigW is offline   Reply With Quote
Old 02-02-2012   #4 (permalink)
Activity: 4.7%
Do you guys have a favorite link on replacing it?
Stopped again today, but started before I could get the filter out. I'll mess with in more this weekend.
Old 02-02-2012   #5 (permalink)
Activity: 99.9%
Crawl under the dash with a light and look for yourself. It's only 3 screws.
When it quits, just have the passenger kick the bottom of the dash.
When I get a dead one, that's all the diagnosis I need to do (well, I hit it with my hand). If the jolt makes it run, the motor is toast.
Old 02-02-2012   #6 (permalink)
Super Mod? What?
Kennykid2002's Avatar
Points: 60,023, Level: 100
Points: 60,023, Level: 100 Points: 60,023, Level: 100 Points: 60,023, Level: 100
Level up: 0%, 0 Points needed
Level up: 0% Level up: 0% Level up: 0%
Activity: 44.1%
Activity: 44.1% Activity: 44.1% Activity: 44.1%
Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute Kennykid2002 has a reputation beyond repute
mrpedo.bear Kennykid2002
Send a message via AIM to Kennykid2002 Send a message via MSN to Kennykid2002 Send a message via Skype™ to Kennykid2002
Yep, just replace the blower motor
__________________
AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
Kennykid2002 is online now   Reply With Quote
Old 02-03-2012   #7 (permalink)
CraigW's Avatar
Activity: 27.9%
Take the black cover off.
Press the release on the 2 pin connector and remove.
Remove 3 screws.
Old 02-04-2012   #8 (permalink)
Activity: 4.7%
My wife got in the car and the AC was not blowing at all. A few minutes later, it started blowing air, but not cold air. Parked to do some shopping, got back in the car and when she turned it on cold air was blowing out.
Would the malfunctioning blower cause the cold air issue as well?
Old 02-04-2012   #9 (permalink)
Activity: 99.9%
Yes. The AC compressor is disabled if the interior fan does not run. You may need to cycle the key off and on to re-enable the compressor once the fan runs.
Why haven't you fixed it yet?
It's only a 10 minute job.
LOL
Old 02-04-2012   #10 (permalink)
Activity: 4.7%
LOL
We bought an extended warranty when we purchased the vehicle and I want to see if it's covered. Also, I'm a cheap a$$ and need to research who sells it the cheapest
Old 02-04-2012   #11 (permalink)
Activity: 99.9%
The whole job should be less than your $100 deductible (unless the dealer wants to charge you for diagnosis).
79310-SNA-A02 $52.75 list.
You can get it cheaper off the internet.
Old 02-04-2012
CivicForums
Honda Civic
Paid Advertisement
Tags
2006 , ac , air , blower , blowing , change , civic , condioter , fan , forum , honda , not , quit , si , stopped
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
New honda civic 2010 having starting problems?
Honda Civic 2010: Key Gets Stuck in Ignition
Third Brake light problem
Civic LX 2008 Oil Leak--please help
Need diagram for fuse box underdash
Replacing Front Bumper on 2006 Civic...
Honda Civic 2006-2010 Transmission Problem (Canada)
2007 Si Tranny
Honda Long-Life Anti-Freeze/Coolant Type 2.
2007 ac problem
Contact Us - Honda Civic Forums - Honda Civic News - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
