Rear Control arms, rear tire wear early models the early models had an issue with the rear control arms (upper) and have a tendency of rapid rear tire wear
New adjustable camber arms, still looks off..
Old 01-19-2012
lbelliott2's Avatar
lbelliott2 is an unknown quantity at this point
I bought my 2007 civic used and it never had the correct rear upper control arms installed. I just had a new camber kit installed today with adjustable arms. When i took my car i noticed that the wheels still look to have a negative camber. I asked for the alignment printout and it stated that the new camber was actually in the +.2 range but the wheels still look to tilt in a bit. Is this normal, should i take it to another shop to get a second opinion.
Thanks
Old 01-19-2012
Re: New adjustable camber arms, still looks off..
From Bulletin 08-001:
Rear camber specification range:
- 1.5° to 0° (- 1° 30’ to 0°)
HTH
Old 01-19-2012
Received 1,440 Likes on 1,196 Posts
camber is measured to the ground, not to the body.
look at the car with this reference in mind and tell us if it still looks high neg cambered. Remember that the body is rounded inversely, so just look at the wheel-to-ground angle.
if it still looks neg cambered, then go back to the shop.
jackoncruzpr
09-29-2015 07:59 PM
Tedverseti
09-29-2015 05:41 PM
rovafa2002
09-28-2015 06:57 PM
mnewcomb
Air Conditioning
09-26-2015 11:02 PM
meicalnissyen
Suspension
09-24-2015 09:28 PM
Quick Reply: New adjustable camber arms, still looks off..
