I have a modified 98 ex and need serious help.
Old 06-18-2011
cfink's Avatar
cfink is an unknown quantity at this point
so im stuck in a really bad dilema with my honda civic that i bought 1 month ago, so here's the story.
I was driving my car, and noticed huge clouds of steam coming from my hood and thru my vents, my raditor was shot and my car over heated. I let my engiene cool down and drove it the half a mile home. The next night I drove it downtown while the engiene was over-heated the whole time. While sitting at a red light my car shut off, and when i went to start it, it barly even turned over. so i parked it, and 3 hours later when to start it because i was getting it towed and it fired right up. i drove it on the trailor and took it home. i replaced the radiotor, and took it for a spin. my engeine didnt over heat once but about 15 mins into my spin my car started strutting and barely getting any tork, sounded like my cadilic convertor was clogged up and the heat could get to the muffler. so the next day i drive it again. i pull over because my car is hardly moving. i stop pop the hood everything seems a ok, and i go to put it in gear and it stalls. try it 3 more times same results. i look at my floor board, right behind the center dash and lone behold theres a fire. i put it out and got it towed home, once again my car starts but barely idles. when i put it in gear, it stalls. i believe my cadlic convertor caught on fire but i havent look at it until tomorrow. any ideas?
i also replaced the spark plugs right before the fire?
im going to straight pipe it, and take the convertor off and see what results i get.
did i burn my tranny up? warp my pistons and headers? should i do a whole new swap? i dont have $ to throw in the air so give me some ideas[YOUTUBE][/YOUTUBE]" target="_blank">[YOUTUBE][/YOUTUBE]" target="_blank">[YOUTUBE][/YOUTUBE]
Old 06-18-2011
Live for the Twisties
MindBomber's Avatar
Re: I have a modified 98 ex and need serious help.
You have a severly blown head gasket.
Old 06-18-2011
Muirsy's Avatar
Muirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the rough
and possibly a warped head from continuing to drive when its overheated
Old 06-19-2011
cfink's Avatar
thanks, im re-doing the exaust tomorrow, and the head gasket. ill let you know what happen's. i just started on here so ill be posting pictures soon. thanks
Old 06-23-2011
cfink's Avatar
ok so i got a new head, and gaskets. fired it up, and ran well. but im leaking anti-freeze under the throtle bottle. idk where its coming from but it hits my muffler and at high temps will cause a serious fire. i cant tell if a line is broken, or what it could possibly be. could i have cracked my block from running at such high temps. let me know what i should do, or look for to casue this pronblem
Old 09-27-2011
Ricerocket2381's Avatar
Ricerocket2381 is an unknown quantity at this point
Sounds like you need a mobile mechanic to pressure that for you. I can find that leak within a couple of seconds.
ken4444
09-30-2015 07:37 PM
juicetayne
09-30-2015 11:02 AM
frank_kleng
09-29-2015 10:55 PM
Islesfan
09-29-2015 03:42 AM
C-Hamm
09-28-2015 10:31 PM
Quick Reply: I have a modified 98 ex and need serious help.
