06 civic..p0128...how to test ect1 and ect2 sensors
Rep Power: 0 06 civic..p0128...how to test ect1 and ect2 sensors
06 civic lx, 1.8liter, 75k miles...I have code P0128 and what to test the two ect sensors before I go and replace them. Does anyone have the ohms or voltage drop spec's for these sensors? Any other advise appreciated.
Trance Addict
Re: 06 civic..p0128...how to test ect1 and ect2 sensors
With the sensors disconnected, there shouldn't be more than 5 or so volts going to the power and ground wires(key on, engine off. You should be able to use accessories). If the power and ground wires don't have the same voltage, you have a problem.
Rep Power: 0 Re: 06 civic..p0128...how to test ect1 and ect2 sensors
Thanks MelJ, a couple of questions on how to do the measurement with the digital volt/ohm meter...
with sensor electrical connection disconnected, measure volt drop from 5V power feed on feed side of connector to power side probe on sensor? Same method for ground side?
Any opinion on measuring live voltage drop while car in running to see if voltage drops when car gets warm?
Rep Power: 210 Re: 06 civic..p0128...how to test ect1 and ect2 sensors
Best ever example of how to test voltage drop: [autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=128&t ransactionid=1305492715-7190173246&posted_by=lazlong_www.civicforums.com&y outube_video_id=BG9U7uOcEeY[/autostream]
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
03-28-2022 07:35 AM
tkcne
04-18-2015 02:33 AM
