Need diagram for fuse box underdash
Rep Power: 0 Need diagram for fuse box underdash
Need a pic or a diagram of underdash fuse box
my car got repo and they f*ucked with my fuze box
rear brake lights dont work can someone tell me which fuse it would be or show me on the diagram
also i cant shift gears from p to r, n, d unless i stick a key or something to manually shift inside of it to the top right side of the shifter
i heard that has its own fuse also so can someone help me on those two things
thanx in advance
thanx in advance
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Rep Power: 163 Re: Need diagram for fuse box underdash
Under-Hood Fuse Box
1. 100A - Main Fuse
70A - EPS
2. 80A - Option
50A - Ignition Switch Main
3. 30A - ABS motor
30A - ABS F/S
4. 50A - Headlight Main
40A - Power Window Main
5. -- Not Used
6. 20A - Fan Motor
7. 30A - Main Fan Motor - A/T
20A - Main Fan Motor - M/T
8. 40A - Rear Defroster
9. 40A - Blower
10. 10A - Hazard
11. 15A - FI
12. 15A - Stop, Horn
13. -- Not Used
14. -- Not Used
15. 7.5A - Oil Level Sensor
16. -- Not Used
17. -- Not Used
18. 15A - Ignition Coil
19. 15A - FI Main
20. 7.5A - MG Clutch
21. 15A - DBW
22. 7.5A - Interior Light
23. 10A - Back Up
Interior Fuse Box
1. 7.5A - Power Window
2. 15A - Fuel Pump
3. 10A - IGI ACG
4. 7.5A - ABS
5. 15A - Audio Amp
6. 20A - Front Fog Lights
7. -- Not Used
8. -- Not Used
9. 7.5A - ODS
10. 7.5A - Meter
11. 10A - SRS
12. 10A - Right Headlights High Beam
13. 10A - Left Headlight High Beam
14. 7.5A - Small Lights (Int)
15. 7.5A - Small Lights (Ext)
16. 10A - Right Headlight Low Beam
17. 10A - Left Headlight Low Beam
18. 20A - Headlight High Beam Main
19. 15A - Small Lights Main
20. -- Not Used
21. 20A - Headlight Low Beam Main
22. -- Not Used
23. -- Not Used
24. 20A - Moonroof
25. 20A - Door Lock
26. 20A - Dr Power Window
27. 20A - HAC Option
28. 15A - Rear Accessory
29. 15A - Accessory
30. 20A - Fr Pass Power Window
31. -- Not Used
32. -- Not Used
33. -- Not Used
34. -- Not Used
35. 7.5A - Accessory, Radio
36. 10A - IG2 HAC
37. 7.5A - Daytime Running Lights
38. 30A - Front Wiper
1. 100A - Main Fuse
70A - EPS
2. 80A - Option
3. 30A - ABS motor
30A - ABS F/S
5. -- Not Used
6. 20A - Fan Motor
9. 40A - Blower
10. 10A - Hazard
11. 15A - FI
13. -- Not Used
14. -- Not Used
16. -- Not Used
17. -- Not Used
19. 15A - FI Main
21. 15A - DBW
23. 10A - Back Up
Interior Fuse Box
2. 15A - Fuel Pump
3. 10A - IGI ACG
4. 7.5A - ABS
5. 15A - Audio Amp
7. -- Not Used
8. -- Not Used
9. 7.5A - ODS
10. 7.5A - Meter
11. 10A - SRS
20. -- Not Used
22. -- Not Used
23. -- Not Used
24. 20A - Moonroof
25. 20A - Door Lock
29. 15A - Accessory
31. -- Not Used
32. -- Not Used
33. -- Not Used
34. -- Not Used
36. 10A - IG2 HAC
Dave1984
07-22-2015 06:10 PM
Civic65
07-19-2015 10:13 AM
JustaRhymez
General 7th Gen
07-10-2015 07:12 AM
