Go Back   Honda Civic Forum > GENERAL > Honda Civic Parts and Reviews
Reload this Page
Tokico HP (blues) with stock springs
Honda Civic Parts and Reviews You can post Honda Civic reviews or Honda Civic part reviews. When posting your Honda Civic reviews please provide as much information about your vehicle for clarification
LinkBack Thread Tools
Old 07-13-2007   #1 (permalink)
dalaw
Bone Stock!
dalaw's Avatar
Compared to stock shocks, ride quality is stiffer (sometimes stiffer than I would like on rougher roads) but more stable(less bouncy), especially on the rear. The front and rear feels more balanced too. Ride quality over the very small speed bumps have also improved, but bigger ones remain a pain to go over. It may have raised ride height about half an inch or so. Better handling also with less body lean. Paid $336 for the set of four and $125 for install.
dalaw is offline   Reply With Quote
Sponsored Links
Old 07-18-2007   #2 (permalink)
Tragedy
skate or die
Tragedy's Avatar
Tragedy is a name known to allTragedy is a name known to allTragedy is a name known to allTragedy is a name known to allTragedy is a name known to allTragedy is a name known to allTragedy is a name known to all
Re: Tokico HP (blues) with stock springs
I am on my second pair of tokico blues. My first pair was installed with H&R springs which were used. My new set up uses tein springs for a smoother ride. These shocks are OK for non adjustables.
Tragedy is offline   Reply With Quote
Old 07-19-2007   #3 (permalink)
Kevbotron
I like my commute
Kevbotron's Avatar
Blues are a good setup for stock springs all the way to drops up to 1.5".. I love mine, on pro-kit springs bumps feel like stock, but I still get the handling of lowering springs... and getting blues and springs seperate are way cheaper than coilovers too
Kevbotron is offline   Reply With Quote
Old 07-19-2007   #4 (permalink)
RHCP0801
RHCP0801's Avatar
they can handle lower than 1.5, i wouldnt say go any lower than around 2" max
RHCP0801 is offline   Reply With Quote
Old 07-20-2007   #5 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
well im gonna be posting a review once i get em installed. stock put up a good fight tho almost 2 yrs on lowered prokit (5 yrs total on the car) before finally giving out.
gearbox is offline   Reply With Quote
Old 07-20-2007   #6 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
love mine!
02BLKCIVIC is offline   Reply With Quote
Old 07-20-2007   #7 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Alpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questioned
Blues for the Win.....
I am setting on Blues with Stock springs..
Alpha 5 is offline   Reply With Quote
Old 08-19-2007   #8 (permalink)
02Civking
New Member
02Civking's Avatar
02Civking is an unknown quantity at this point
dumb question, but are the tokicos shocks/struts? I know the spring is different, but people always say replace the struts and shocks...i was under the impression that it was one piece!
02Civking is offline   Reply With Quote
Old 08-19-2007   #9 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Talking Re: Tokico HP (blues) with stock springs
You have struts on the civic but to answer your question.
Shocks and struts are two different parts that perform similar functions on various suspension systems
Shock absorbers" are physically separated from the car's springs. A "strut," on the other hand, is a shock absorber with a spring that fits around it. Struts are common these days because they save space. But they cost more because the springs have to be removed before the "shock absorber" part of the strut can be replaced. And removing springs is a job that requires special tools--most importantly, a Bronko Nagurski football helmet!
Or:
For strut suspensions, the spring is held by the strutwith the strut providing structural support for thevehicle. Struts are most common on cars. Shocks, on the other hand, are mounted directly to the vehicle’s frame on one end and the lower suspension on the other. Shocks provide no structural support for the vehicle. Shocks are most common on trucks,vans and SUVs.
Old 08-19-2007   #10 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
I did a search and I was kinda wrong, this came directly from KONI's web site.
"Shocks and struts are similar in that they both damp (slow down) the vehicles motion. The key difference of a strut vs. a shock is that a shock only controls the cars motion while a strut is a locating member of the suspension. What this means is that if you remove a shock the spindle or axle will still be completely attached to the vehicle. If you remove a strut the spindle or axle will be able to move outside of its normal motion. Shocks and struts may or may not have a spring mounted to them either. It is often assumed that any damper with a spring is a strut, this is not the case."
Old 08-20-2007   #11 (permalink)
02Civking
New Member
02Civking's Avatar
so buying the tokico shocks means i will need to buy struts? i was going for tokicos and neuspeed sport springs.. the shocks do come with dampers? a little off topic the drum on the back looks like crap! any high heat paint brands u can think? don't say convert b/c I can't afford it.
Old 08-20-2007   #12 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
The fact that the tokico shock acts as a stress member of your suspension makes it a strut.
So all you will need to do is buy the Blues and rent or borrow a spring compressor, pick up a 12 pack of cold beer, grab a buddie and kill a few hrs...
There is a good DIY somewhee around here. Just do a search for it.
Old 08-20-2007   #13 (permalink)
02Civking
New Member
02Civking's Avatar
thanks for the input, 12 pk of Boston Lager sounds good, though I think i'll get a local mechanic to do the spring compression lol. heard too many horror stories about the spring coming off and going through the roof lol....how long do u think it will take someone to put the shocks and the springs on? should i lower first or put the kaminari kit on then lower it?
Old 08-20-2007   #14 (permalink)
gearbox
Super Moderator
lower first. takes a shop 3-4 hrs if nothing goes wrong. big job. get the set of tokico and lowering spring of your choice below 2 inch drop. i think we have strut in front and shock in rear, doesnt matter youre just replacing it with new stuff
Old 10-05-2007   #15 (permalink)
Devani
Super Member
Devani's Avatar
Devani should not be questionedDevani should not be questionedDevani should not be questionedDevani should not be questionedDevani should not be questionedDevani should not be questionedDevani should not be questionedDevani should not be questionedDevani should not be questionedDevani should not be questionedDevani should not be questioned
I have tokico/stock springs over a year and a half now...I have 215/45/17 wheels and the ride improved dramatically...$325 for parts and installation was free because I did it...got alignment a week after...best money spent..
Devani is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Philips Xtreme power +80 H4 bulbs
Weapon-R secret weapon intake
RS*R catback exhaust
ingalls "stiffy" torque damper
philips silvervision cornering bulbs
1997 civic headers
HKS Hi-Power Axle-Back Exhaust
01 TYC Projectors
Neuspeed Front Upper Strut
SI/DC5 sidemarkers
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
