Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 2 Weeks Ago   #1 (permalink)
Demeter
New Member
Demeter is an unknown quantity at this point
Green & Blue Gauge lights not working
I bought my 99 Honda Civic HX a few days ago. And all the dash lights and things work except for the blue/green bright lights that should light up the gauges and I think the indicator lights as well. It is not the dimmer switch because it works when I move it. The only thing that works on the part behind my steering wheel is basically the backlight on the odometers.
Now one night the lights did come on for a minute but they went off again. And last night I was checking the fuses and they just started to work again, but now they stopped working again.
I've checked most of the fuses under the dash and they are all fine. I am not 100% sure which fuse they go to because # 30 is working since all the dash lights work besides though. I'm not sure what I should do now.
Demeter is offline   Reply With Quote
Sponsored Links
Old 2 Weeks Ago   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Green & Blue Gauge lights not working
might be a loose ground wire but im not even sure where to look.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 2 Weeks Ago   #3 (permalink)
OCDjG
Member
OCDjG will become famous soon enough
From what it sounds like to me is that you have a gauge overlay over your stock gauges. At times they flicker on and at times they flicker off right? Well if I'm right about you having the overlays then that sounds like the transformer that is powering them up is going out. There is really nothing you can do to fix it. They just die after a while. You'll have to replace the entire set for a new one. Personally I'd just remove it and leave it stock. If you want brighter gauges then look into leds.
OCDjG is offline   Reply With Quote
Old 2 Weeks Ago   #4 (permalink)
gearbox
Super Moderator
check the ground first, its usually the problem cause shops dont know where to put it. mine did the same thing flickering and going out, finally i moved the ground to a good spot on the chassis and it was back to normal.
__________________
www.lubecontrol.com
Member 1025782
Old 2 Weeks Ago   #5 (permalink)
Demeter
New Member
Where could I check the ground at? I'm not too familiar with cars etc.
I took it to where I bought it and they said it would be like 50$ just to check to see what the issue was.
Old 2 Weeks Ago   #6 (permalink)
gearbox
Super Moderator
gotta open up the surrounding areas around the cluster and trace the wires. maybe look under the dash where the fuse cover is. usually they find a bolt and ground it, but most of those places make for lousy grounds.
__________________
www.lubecontrol.com
Member 1025782
Tags
01 , 2000 , 2001 , blue , bright , car , change , civic , dash , gauge , green , honda , lights , remove , stopped , working
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
