Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 2 Weeks Ago   #1 (permalink)
fatboyflip
New Member
fatboyflip is an unknown quantity at this point
12v power supply in console always on
I have an 09 civic ex. I would like the 12v power outlet in the console to be live when the ignition is off. any ideas? To remove this ad, register today for free or log in if already registered!
fatboyflip is offline   Reply With Quote
Sponsored Links
Old 2 Weeks Ago   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: 12v power supply in console always on
you have to run a new wire from the battery + terminal (with fuse ofcourse) directly to the socket. then just cut the factory power wire and hook up your new one.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 2 Weeks Ago   #3 (permalink)
bigaudiofanatic
Member
bigaudiofanatic is an unknown quantity at this point
Send a message via AIM to bigaudiofanatic
Not to the battery per say. You can find a constant 12volt power wire such as the one from the radio or one from the fuse box. Yes you can run one to the battery but there is no real need too. Just make sure if you do run one from the abtter to the plug that you install a 5 amp fuse somewhere in that line. You can get stand alone fuse holders at your local auto store.
bigaudiofanatic is offline   Reply With Quote
Old 2 Weeks Ago   #4 (permalink)
BJanzen
Senior Member
BJanzen's Avatar
BJanzen is a glorious beacon of light BJanzen is a glorious beacon of light BJanzen is a glorious beacon of light BJanzen is a glorious beacon of light BJanzen is a glorious beacon of light
Send a message via MSN to BJanzen
It would be a much better idea to run it from the battery...You dont want to splice into the radios power...Listen to gearbox.
__________________
All audio...
BJanzen is offline   Reply With Quote
Old 2 Weeks Ago   #5 (permalink)
gearbox
Super Moderator
yeah you really dont want to be stealing power from the radio. it needs every bit it can get. in fact i wired my radio's power wire directly to the battery too. the 12v socket consumes alot of power and im surprised how thin the stock wiring is. my new ashtray/lighter did come with an upgrade wire harness from honda tho so i feel safer using it for hi amp draw devices.
__________________
www.lubecontrol.com
Member 1025782
Old 2 Weeks Ago   #6 (permalink)
bigaudiofanatic
Member
You can do it either way, I use to have radio, cd changer, Sirius, ipod and more all on the radio wire and had a really nice setup. Of cores I was not using the internal either. If you do run it to the battery make sure to cover and protect the wire from the heat of the engine and use some beefy wire such as 12 gauge, just make sure to match your ground wire to the same gauge that you use for your power wire.
Tags
07 , 12 , 12v , 2001 , 2004 , 2007 , car , civic , crv , honda , outlet , power , supply , volt , working
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
