Honda Civic Electrical, Wiring, and In Car EntertainmentThere's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
1998 Honda Civic EX Sedan 5-Speed
Viper 5002 alarm system
Can you please look this over, make sure everything looks OK. This is my first alarm install. I just want to make sure I do this right the first time.
520T Battery Backup Module
RED .. (15A fuse 12” from power source) to 12V Constant [18 gauge wire]
GRAY (+) 12V Output - to Viper (+) 12V Constant
BLACK .. GROUND to Chassis
BLUE (-) Output to Control Module - tap H2/2 GREY (-) Hood Pin Input, Zone 6 (22 gauge)
Parking Light Flash Relay (30 amp SPDT)
86+87 .. tap 520T RED +12v Constant
30 .. tap Parking Lights (+) RED/Black (drivers door sill/front of the fusebox)
85 .. to H1/11 WHITE [set to neg. output with jumper on the side of brain]
Relay for 2 sirens (30 amp SPDT)
30 .. to sirens
85 .. to H2/7 LIGHT BROWN (set to constant output in menu with program switch)
H1 Harness
H1/1 .. NOT NEEDED (is for trunk pop, you can add an actuator and relay to do so if you want)
H1/2 .. to 520T GRAY (15A fuse on Viper side)
H1/3 .. to 2 sirens RED (split wires, and place a 1A fuse on the one under hood to protect from grounding)
H1/4 .. tap into Ignition BLACK/YELLOW (ignition switch harness)
H1/5 .. GROUND
H1/6 .. NOT USED
H1/7 .. to Trunk BLUE/BLACK
H1/8 .. JOIN with H1/9 to (door trigger = light green/red (-)
H1/9 .. JOIN with H1/8 to (door trigger = light green/red (-)
H1/10 .. NOT USED
H1/11 .. to 85 Parking Light Flash Relay [set to neg. output with jumper on the side of brain]
H1/12 .. NOT NEEDED (is for kill relays, window/sunroof mod., led scanners, piggyback voice modules, etc)
H2 Harness
H2/1 .. NOT NEEDED
H2/2 .. to hood pin (18 gauge wire)
H2/3 .. NOT NEEDED
H2/4 .. NOT NEEDED
H2/5 .. NOT NEEDED
H2/6 .. NOT NEEDED
H2/7 .. to Siren Relay 85 (set to constant output in menu with program switch)
H2/8 .. NOT NEEDED
H3 Harness
H3/A .. GROUND
H3/B .. NOT USED
H3/C .. to neg. output door lock = green/white (-)
H3/D .. GROUND
H3/E .. NOT USED
H3/F .. to neg. output door unlock = green/orange (-)
H3/G .. GROUND
Sensor 2
507T Audio sensor
Sensor 3
507M Tilt Sensor
Immobilizer
(Normally Closed)
87a GREEN/BLACK to Starter side (power side)
..cut Starter BLACK/WHITE (ignition switch harness)
30 GREEN/WHITE to ignition side (load side of wire)
Sponsored Links
