Honda Civic Electrical, Wiring, and In Car EntertainmentThere's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
Can anyone tell me what color is the 12 Volt signal wire comming off the OEM fog light switch? The wire that allows the fog lights to kick on when you switch your headlights on.
Sponsored Links
They are Honda OEM from the dealership. Previous owner got them like that. I am looking at my Chilton manual and I cant seem to match the wires to the diagram.
looking at a schematic for a 2004, it looks like you need to tie the blue wire on the switch to a power source. i would put it on the red/yel of the parking lights. that way you won't forget to turn them off and kill your battery (like i have on previous cars.) you'll have the warning buzzer to remind you.
yeah i used the park lights for mine too. and that way you can leave the fog button pushed all the time and they will turn on automatically with the park lights.
__________________
Restore Performance, Reduce Costs www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
Its so funny u say that because I know its the blue wire for the 2003 and lower. But I don't have a blue wire coming off the fog light switch. I am looking at the Chilton book and it shows 5 wires coming off the switch. In reality I have like 9, and the Chiltons shows a blue wire.. I dont have a blue wire coming off my switch. I am pretty sure these are OEM lights. I have OEM glass housings, an OEM switch and everything its even in the OEM loom. If it helps I can take a picture of it.
If I wire it to the 12 Volt Acc wont it go off once the ignition is off?
if you don't have blue, you prob don't have Honda OEM, but an ebay set. the ebay's are almost identical, that's why so many have them. if you have a multimeter, you can ohm through the switch while actuating it, and figure out which wire goes to the fog light relay.
Do I have to have the switch plugged in while I check it? I always thought mine was OEM. The bulb housings are glass and OEM Stamped Stanly on them. Unless the man who owned the car before me got them installed afterward.
Ok I checked the wires with out the switch plugged in, but I doubt it matters. Here is what I have.
Starting from the top left of the switch to the bottom right.
A single Red and Yellow Wire (Didn't get power with the lights on)
Next one to the right of that 2 red and black wires connected to the same pin. They each got 12 Volts with the headlights lights on, and no Volts with the headlights off.
Next one to the right of that is Red and black only a single wire
Next one to the right of that pin is 2 solid red wires.
Below the spot of the red and yellow wire is empty.
Then under the spot of the 2 solid red wires there are 2 red and white wires.
Any ideas. I am assuming it has something to do with one or both of the red and black wires?
very possible. no, you'll want to remove the switch and check on the backside at the terminals. what you're trying to do is trigger power to fog light relay 1 on the red/yel wire as you desire.
i think we posted at the same time. try getting a jumper wire and put 12+ on the red/yel with the switch off. if the fogs come on, take the switch out and manually actuate the switch while reading resistance. check the other terminals to see which wire is connected to the red/yel through the switch. when you find it, that's the one you want to tie to the park lights or acc.
odd..I jumped the red/yel wire and my Driver side light came on. Both my high beams and my other passenger side light came on and it looks like I have DRL lol..Did I fuck up?
Could it be that each red black wire in that pin is for each fog light?
as far as i know, oem lenses are polycarb. also a dead giveaway is the glare shield around the bulb (metal cylinder around the sides of the bulb) that only oem fogs have.
__________________
Member 1025782
