Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-13-2009   #1 (permalink)
Karado58
New Member
Karado58 is an unknown quantity at this point
Question Diodes and Relays on a Viper 5002???
I have a 1998 Honda Civic EX Sedan 5-Speed
Installing a Viper 5002 alarm system
Add-ons:
Tilt sensor 507M
Glass break sensor 506T
Backup battery 520T
2 Piezo sirens
I am totally confused as to the using of diodes and relays, or if they are even needed on the above setup?!
Can someone please simplify if they are needed, if so where?
Please do not tell me to have it professionally done, if i had the money I would not be here asking for help.
Thank you in advance.
Karado58 is offline   Reply With Quote
Sponsored Links
Old 10-13-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Diodes and Relays on a Viper 5002???
im not exactly sure, it should have come with installation manual. relays are like a hi power switch. it takes a low current trigger signal to switch them on, then they draw power directly from the battery to the device they power. they are usually needed for accessories that use alot of power. but in alarm installs ive seen them used to reverse wire a circuit, such as turning a ground into a positive so to speak. diodes are just small things you put inbetween a wire so that power only flows in one direction instead of both ways. you should read thru the install manual it tells you how to wire up everything.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 10-13-2009   #3 (permalink)
Karado58
New Member
Thank you gearbox...I'll look at the manual more carefully.
Old 10-13-2009   #4 (permalink)
gearbox
Super Moderator
also some of those addons are useless or can cause issues later. the glass break sensor doesnt do anything, and if they hit the car hard enough to break glass, the shock sensor will take care of it anyways. but most thieves these days dont even bother breaking windows. you can get in by just wedging the door molding open and sticking in a metal rod to reach the power unlock button. takes maybe 10-20 secs. the backup battery is also useless, because once you remove the alarm fuse under the hood (which must be within a foot of the battery), then it disables the entire alarm. i had one but took it out after it went bad and started to constantly drain my main car battery trying to keep itself charged.
__________________
www.lubecontrol.com
Member 1025782
Old 10-13-2009   #5 (permalink)
Karado58
New Member
Thanks for the advice gearbox...I'll keep it in mind before I spend any more money.
Tags
5002 , alarm , battery , diodes , install , manual , open , relay , sensor , set , shock , siren , stereo , viper , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
