Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-23-2009   #1 (permalink)
20psiek
New Member
20psiek's Avatar
20psiek is an unknown quantity at this point
turbo map sensor help
ok i have a 1997 civic ex coupe with a b20 block and b18 type r head turboed. Something is up with it i was driving down the road and i got on it a little bit and hit a bump kinda hard. After i hit the bump my car started running like crap i had to keep my foot on the gas to keep it running if i took my foot off the gas it would die. I checked out the check engine light and it said my map sensor was bad i ordered a new map sensor but im confused on how to hook it up the wires are different colors on the wiring harness there is a green red and yellow wire but on the map sensor there is a black green and red wires does anyone have any clue on which wire goes where? thanks To remove this ad, register today for free or log in if already registered!
20psiek is offline   Reply With Quote
Sponsored Links
Old 09-23-2009   #2 (permalink)
bomerman19
Super Member
bomerman19's Avatar
bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned
Re: turbo map sensor help
we need a little more info what engine mangement system are you using? is the map sensor on the engine a stock map sensor or an aftermarket map sensor? what map sensor did you pick up?
on turboed cars the stock oem honda map sensor tends to get crazy around 9 to 10 psi so most people stick in an aftermarket map senor that can handle high levels of boost.
bomerman19 is offline   Reply With Quote
Old 09-23-2009   #3 (permalink)
20psiek
New Member
20psiek's Avatar
it has a p72 ecu tuned by drift and drag and i got a motorola 2.5 bar map sensor
Old 09-23-2009   #4 (permalink)
bomerman19
Super Member
bomerman19's Avatar
does it plug into were the old stock map used to go?
Old 09-23-2009   #5 (permalink)
20psiek
New Member
20psiek's Avatar
it is just three wires there isnt a plug that came with the new map sensor
Old 09-23-2009   #6 (permalink)
bomerman19
Super Member
bomerman19's Avatar
oh so it is hard wired in hmm I believe the black green goes to the yellow wire but I am not sure there is probably a diagram up or I am sure some one on hondatech knows. this is mostly a 7thgen/8thgen site it actually used to be called 7thgencivic.com back in the day when it was decent. some of us have knowledge of of the older gens but there is a lot more info over on hondatech sorry
Tags
1997 , civic , diagram , gm , honda , hook , install , map , motorola , oem , problem , problems , sensor , turbo , wire , work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
