Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-23-2009   #1 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
12 Volts but bulb doesnt light
I know its not a Honda lol. But I just bought a 1988 Nissan Sentra in manual so that I could learn how to drive stick. Since my civic is automatic and I just wanted a beater to learn on. I am having trouble with the third brake light. For some reason I cant get it to work. I have gotten all of the other lights to work by simply just changing the bulbs. I changed the bulbs in these two sockets as well with brand new bulbs, but nothing. So I removed the bulbs and check for power I am getting 11 volts there. I dont understand whats going on. Is it the amperage that is not getting there? Any electrical guys give me ideas. To remove this ad, register today for free or log in if already registered!
04 Honda Civic is offline   Reply With Quote
Sponsored Links
Old 09-23-2009   #2 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Re: 12 Volts but bulb doesnt light
Could be an open ground... Are you measuring voltage on both terminals ?? If voltage is present on both sides check the ground or provide a ground with a jumper as a quick test.
CraigW is offline   Reply With Quote
Old 09-23-2009   #3 (permalink)
04 Honda Civic
Super Member
I jumped the ground with no luck. Used a few different grounds too. I get 12 volts on both sockets. As soon as I put a bulb in one socket the 12 volts dissapears from both sockets. I am not 100% sure whats going on but I know there is probably only 12 volt signal and no amperage to the sockets. Any ideas on what to do?
Old 09-23-2009   #4 (permalink)
CraigW
Platinum Member
CraigW's Avatar
Do you have a 12v test light ??
It will provide a load for the circuit. You could also check continuity for the ground and continuity between the other bulbs that are workings hot lead and the high mounts hot lead.
Old 09-24-2009   #5 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
hmm usually the 3rd brake light is tapped off the wires on either the left or right side brake bulb. so maybe retrace those wires. its possible the socket is messed and not making good contact, or they are touching together idk.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 09-26-2009   #6 (permalink)
electric130
I.C.E. Mod
electric130's Avatar
electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned
i used to see this on aircraft in the Air Force. you'd measure good voltage, but the component would work. it was usually broken wire strands on a connector. say a wires got 15 strands. if all are broken but 1 or 2, you'll read voltage, but theres not enough of the conductor to carry the load. so i'd give the wires at each connector a good hard tug. if they're good, you wont damage them. if they're weak or broken, they'll come out and you'll know where the problem is.
electric130 is offline   Reply With Quote
Tags
03 , 2004 , 3rd , brake , bulb , bulbs , civic , crv , honda , install , light , remove , si , tail , volts , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
