Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-03-2009   #1 (permalink)
devlsh1
New Member
devlsh1 is an unknown quantity at this point
Horn wiring and what are these?
I have a 1994 Civic 2dr EX that I just bought and trying to fix all the issues the PO inflicted. The horn buttons were removed with a button on the dash as the horn. Here are some pictures of wires I am trying to figure out where they go in the drivers side front of the car..please help.
Hopefully one of these connectors goes to the horn...but my cooling fan keeps coming on with the melted connector.
ID:	77225   Click image for larger version
ID:	77226   Click image for larger version
devlsh1 is offline   Reply With Quote
Sponsored Links
Old 09-04-2009   #2 (permalink)
devlsh1
New Member
Re: Horn wiring and what are these?
Update...installed new horn buttons, now I cant get rid of SRS light, what now?
Old 09-05-2009   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
this is for 01+ civic but may work for you
Reset Your SRS Light
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 09-05-2009   #4 (permalink)
gearbox
Super Moderator
__________________
www.lubecontrol.com
Member 1025782
Old 09-07-2009   #5 (permalink)
devlsh1
New Member
Worked great..thanks!!
Just still cant horn to work..help?
Old 09-07-2009   #6 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
I would start from scratch. You would just need a relay an inline fuse holder and some wire. (assuming there is a horn already there)
CraigW is offline   Reply With Quote
Old 09-08-2009   #7 (permalink)
devlsh1
New Member
Horn is there and grounded to the frame. I have no problem running a wire through the fire wall up towards the horn...but do I run it up into the steering wheel or attach it where?
Old 09-09-2009   #8 (permalink)
CraigW
Platinum Member
CraigW's Avatar
If you are going to use the factory horn button it could be more work. Do you think the factory stuff is still there ?? ( you mentioned an external horn button)
Either way the only wire needed coming through the firewall is only going be a ground for the horn relay coil.
Old 09-14-2009   #9 (permalink)
devlsh1
New Member
I dont know exactly how much is there or removed from the stock wiring. When I bought the car the stock horn buttons were popped out of the wheel and there was a button (looked like a staples "easy" button) stuck to the dash. It had a wire going to the fuse box and another going to the horn. Where would the stock horn relay be?
Old 09-14-2009   #10 (permalink)
CraigW
Platinum Member
CraigW's Avatar
The stock horn relay would be in the under hood box.
If the wiring for the factory button on the wheel is not functioning...?? It may be a challenge to restore. May be the reason they had another button.
Tags
2002 , 94 , button , car , civic , dashboard , find , honda , horn , installing , lights , scratch , wires , wiring , work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
