Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-18-2009   #1 (permalink)
vsTerminus
Member
vsTerminus's Avatar
vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned
Question '02 Coupe Alternator whine troubles
Edit: Problem solved, it was the shitty EQ causing the whine.
Head Unit has been replaced with a new one (Pioneer FH-P800BT with built in EQ)
The Setup:
- Pioneer DEH-4600MP deck
- Equalizer (I forget what brand, pretty cheap, bought off a friend)
- Pioneer 760W 2-ch amp powering the door speakers (stock up front, aftermarket pioneer 6x9's in the back)
- Twister 1250W 2-ch amp powering the subs in the trunk
- 2x 10" Premier TS-W1500SPL subs (1500W max, 600RMS)
- 1.0 Farad Stinger capacitor
- All power/ground wire is 4AWG
- Twister amp is grounded to metal in the trunk, amp sits on sub box in trunk.
- Pioneer amp is grounded to the seat belt bolt on the driver side, amp sits under driver seat
- RCA cables are all StreetWires Zero-Noise
- Power runs from Battery to a 150Amp fuse, then to my capacitor, then to a distro block which splits to each amp. Twister amp and Capacitor share a ground, Pioneer amp has its own ground.
- Power runs along the passenger side, RCA cables and remote wire run along the driver side
The Problem:
I'm getting alternator whine through my speakers (Mostly noticeable when I accelerate, of course) after upgrading my stereo. Self-installed.
When does it happen?
The moment I wire up my Equalizer I get alternator whine. If I unhook it and run directly from the deck I have no problems at all.
The EQ currently shares power and ground with the deck on the wiring harness.
What I have tried:
Ground Loop Isolator
Adjusting wires to try and separate power from RCA further
What I'm going to try:
Running the ground from the EQ into the ground on one of my amps to let it share that instead of sharing with the gound on the deck's wiring harness
OR giving the EQ its own ground entirely.
What I want to know is simple:
Does anyone here have any ideas/suggestions for me to get rid of the alternator whine?
How far apart do RCA cables have to be from power wire to avoid unwanted noise?
Can RCA cables be run along side remote wire without picking up noise?
Please let me know if you need pictures or more information.
And I did search the forums, hopefully I didn't miss a solution to this problem that's already been posted.
Thanks!
vsTerminus is offline   Reply With Quote
Sponsored Links
Old 07-18-2009   #2 (permalink)
bigaudiofanatic
Member
bigaudiofanatic is an unknown quantity at this point
Send a message via AIM to bigaudiofanatic
Re: '02 Coupe Alternator whine troubles
Well sounds like your rcas are not getting a good ground, the cause can be that cheap EQ. What I would do s take a long peice of wire wrap it around the rcas going into and out of the EQ and ground that that should take care fo the noise. If it dose not than it is the EQ itself.
bigaudiofanatic is offline   Reply With Quote
Old 07-18-2009   #3 (permalink)
vsTerminus
Member
vsTerminus's Avatar
Thanks for the reply, I just got inside from trying a few things.
The EQ has its own ground now, still getting whine
I did notice that the whine gets significantly quieter, if not totally disappears when Air Conditioning is off, but I suppose that has to do with how much the alternator is working at the time and AC would cause that.
I'll try the wire solution, and if that doesn't work maybe I'll just look into a new EQ.
Recommendations for a decent EQ, anyone?
Old 07-19-2009   #4 (permalink)
kcari
Ultimate Member
kcari's Avatar
kcari is a name known to all kcari is a name known to all kcari is a name known to all kcari is a name known to all kcari is a name known to all kcari is a name known to all kcari is a name known to all
Send a message via AIM to kcari
how does the wine sound exactly- is it metal on metal and does it whine when you're not accelerating?
__________________
http://www.youtube.com/watch?v=Ya-bq3zokeU
^ EPIC EM2 VIDEO!!!
My EM2 is MAD FAST YO;
Cars that I've smoked
- Smart, Prius, Fit, Yaris, Aveo.
kcari is offline   Reply With Quote
Old 07-19-2009   #5 (permalink)
vsTerminus
Member
vsTerminus's Avatar
What do you mean by metal on metal?
The whine is present all the time, but the pitch increases as I accelerate and decreses when RPMs drop down again.
It goes away if I unhook the Equalizer, but is present when the EQ is wired up, regardless of whether I have it set to actually process the signal.
I've tried unplugging the radio antenna and that does nothing as well.
It's definitely coming from the 6x9s in the rear deck. I don't hear anything from the subs in the trunk.
Tomorrow I'm going to try unhooking the deck entirely and running my iPod directly into the EQ to see if it's the EQ itself, or maybe has something to do with the amount of power I'm drawing from the battery.
Old 07-19-2009   #6 (permalink)
electric130
I.C.E. Mod
electric130's Avatar
electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned
Quote:
i think you've already found the answer. you said in the first post it was cheap. to me, you've already troubleshot the problem. get rid of the cheap EQ.
electric130 is offline   Reply With Quote
Old 07-19-2009   #7 (permalink)
bigaudiofanatic
Member
I have to agre with him also I am not talking about the EQ's own ground ou have to ground out the rcs outputs somtimes pioneers and chaper stuff do not have the best rca grounds. Wrap a peice of wire aroudn them and ground it. If not than just take the EQ out. Here is a pic of what I am talking about.
Old 07-19-2009   #8 (permalink)
vsTerminus
Member
vsTerminus's Avatar
Thanks for the pic. I'll give it a shot.
Also, I'm looking into a Pioneer DEQ-7600 15-band DSP equalizer. I'd need a double-DIN dash mount for it, but it looks good if I can find one for a decent price.
Old 07-20-2009   #9 (permalink)
hondaguy2582
Member
hondaguy2582's Avatar
hondaguy2582 is an unknown quantity at this point
Most Pioneer headunits get that alternator noise if installing the unit with the battery plugged in. Try grounding the rcas as mentioned.
hondaguy2582 is offline   Reply With Quote
Old 07-20-2009   #10 (permalink)
electric130
I.C.E. Mod
Quote:
my Pioneer does not. not from either set of RCA's.
there's no noise without the cheap EQ plugged. plug in the cheap EQ, and there's whine. maybe it's simple logic, but my bet's on the cheap EQ being the culprit if the Pioneer doesn't make noise to the amps without the EQ.
Old 07-21-2009   #11 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
lol hes right, my old pioneer deck never made whine. throw away the eq, you dont need it anyway when the pioneer deck has its own. most have 15 band eq with lots of frequency ranges.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 07-21-2009   #12 (permalink)
bigaudiofanatic
Member
I agree but it is only in some cars it depends on the car as well, but they do have crappy rca grounds. That is why I love alpine just so darn good.
Old 07-23-2009   #13 (permalink)
vsTerminus
Member
vsTerminus's Avatar
So it turns out it was the EQ.
I ran the EQ directly without the Pioneer deck plugged in at all. There was whine.
The deck (Pioneer DEH-4600MP) Only has a 3-band EQ, which doesn't allow for great enough separation. You end up with a muddy sound if you turn up the "low" frequency. This is the whole reason I wanted an EQ in the first place.
So I settled on buying a new Double-DIN deck with a built in 7-band EQ, iPod USB support, Bluetooth handsfree support, and no annoying preset buttons (I never listen to the radio, what do I need 4-8 useless buttons for?)
Thanks for all your help everyone!
Pioneer FH-P800BT
Tags
02 , 2007 , alternator , amp , amps , capacitor , cd , civic , coupe , deck , ground , honda , install , installing , rid , stinger , whine , whining
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
