Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-27-2009   #1 (permalink)
The RedheadPimp
New Member
The RedheadPimp is an unknown quantity at this point
Exclamation Slow drain on battery
Alright so here is what happened. I was driving down the highway a few days ago and the battery died while driving cause the car to shut off on me no matter how much i put the throttle to the floor. I replaced the battery about 16 months ago so i figured it was still good. I went ahead and bought a 100% new alternator and installed it, charged the battery. Everything seemed fine so i decided to take it out and it died after about 90 min of driving. I thought maybe my ground from the battery was bad so i went and replaced the terminal and wire and wet sanded the spot where the terminal wire mounts onto the engine and replaced the ground from the engine to the front frame. I am still having problems and it is quite frustrating. I took the car down to a local advance auto parts and they hooked a machine up to check my system. The reader came back with results saying that the battery was good and the alternator was good. It says i have a small drain tho, o.o2 A. I am running 2 amps to power my 4 12" subs in the car but have had them in the car for well over a year now and this is the first problem i have had. Both amps are connected directly to the battery with a fuse in the line. I am at a point where I dont know what to do. Any suggestions? To remove this ad, register today for free or log in if already registered!
The RedheadPimp is offline   Reply With Quote
Sponsored Links
Old 06-28-2009   #2 (permalink)
electric130
I.C.E. Mod
electric130's Avatar
electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned
Re: Slow drain on battery
check the big power fuse between the alternator and the battery. should be around 80A i think.
electric130 is offline   Reply With Quote
Old 06-28-2009   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
it could be a loose power cable from alternator to the battery. are you reading around 14v when the car is running and you measure the voltage at the battery terminals?
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 06-29-2009   #4 (permalink)
The RedheadPimp
New Member
I fuse is fine. It was the first thing i checked. Should i replace it even though its still good? I will double check the cable but it is reading 14v when the car is runnning.
Old 06-29-2009   #5 (permalink)
electric130
I.C.E. Mod
take it to autozone and have them check the charging system. it's free.
Old 07-06-2009   #6 (permalink)
The RedheadPimp
New Member
I took it to autozone and they were no more help than advance. i am starting to think that i may have just bought a faulty alternator that is still reading as good for some reason. I had a few buddies look at the car and said the same thing. Or it could be from my spark plug coils. I am really not sure what to do at this point though.
Old 07-06-2009   #7 (permalink)
gearbox
Super Moderator
are you sure they are testing the alternator properly? because it may read "good" as far as volts, but the amp output could be way low like 20-30 amp instead of 70. that would cause slow drain of the battery while driving cause there is not enough power to run the car and charge the battery. i used to work for advance and its real easy to misdiagnose a bad alternator if you dont know the machine well.
__________________
www.lubecontrol.com
Member 1025782
Tags
1994 , 2003 , battery , car , civic , drain , electrical , find , fog , ground , honda , lights , running , slow , starter
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
