Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-22-2009   #1 (permalink)
JACK6306
New Member
JACK6306 is an unknown quantity at this point
Tail light craziness
Hello Guys & Gals, I am new to this board but was hoping that someone here could grace me with the knowledge to point me in the right direction for fixing my nelly belle. I have a 95 Honda civic dx with about 245,000 miles and she is still going strong. A few weeks ago I realized one evening that my rear tail lights are staying on even when the car is completely off. There is one light on the left side that does not come on.The brakes lights come on and off when the brakes are applied but the rear running lights just stay on no matter what. I have read a few post and have looked at the fuses under the hood and dash. I have also looked at the bulbs in the rear and all look fine no burnt bulbs any where. I have attached a picture that shows the car off with the lights on. I have just pulled the fuse for the rear tail lights until I get this problem solved. Please any help would be greatly appreciated. To remove this ad, register today for free or log in if already registered!
JACK6306 is offline   Reply With Quote
Sponsored Links
Old 06-22-2009   #2 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Re: Tail light craziness
Are your front markers and dash lights coming on as well ??
What is the designation (name) of the fuse being taken out ??
If you pull the "taillight relay" will that make them go off.
CraigW is offline   Reply With Quote
Old 06-22-2009   #3 (permalink)
JACK6306
New Member
Nah, my front markers and dash lights are not staying on like the rear lights. I believe that under the dash I have checked fuse 19 30 & 32 I beleive that those were the three fuses that I checked out under the dash. The fuses uner the hood I just checked the one for the tail light. All the fuses were in good shape. In order for me to keep the lights off I pull the fuse under the hood for the tail light and the light goes off at that point. Also I just replaced the bulb thinking maybe that would solve the problem but no it did not. In addition to adding a new bulb I also disconnected the 7p & 4p connectors from the light combination switch and the lights still stayed on. Not sure what to do next any help would be appreciated.
Thx
Old 06-22-2009   #4 (permalink)
CraigW
Platinum Member
CraigW's Avatar
Seems strange that the rears can be on and not the fronts (should be on the same circuit) Both front & rear and dash lamps should be switched by the "taillight relay" can you hear a relay click under the dash when you turn on the markers ?? If so try to locate this relay and take it out to see if the rears stay lit.
You should try to download the free 96-00 Civic factory service manuals from the web. It will help out.
Old 06-23-2009   #5 (permalink)
JACK6306
New Member
Hello All, I am so embarassed to say this but it wasn't the running lights that were out it was the brake lights that are the problem. The bulbs are all fine I think that it might be the brake light switch but wanted to see what you guys might think.
THX.
Old 06-23-2009   #6 (permalink)
CraigW
Platinum Member
CraigW's Avatar
Most likely... It may be out of place (plunger not able to operate) or the switch could be bad (always closed contacts)
Should be a simple fix though. Inspect the operation of the switch when moving the pedal. You should be able to see what is occuring.
Edit: I could not find any threads but someone mentioned before about this issue... Somehow there was a hole and it allowed the plunger to not get pushed when the brake pedal was released ?? They used a plastic plug to fill in the hole and it solved the problem.
Here is the thread, Not sure if the 6th gens are similar or not --> Stuck Brake Light Switch
Old 06-23-2009   #7 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
that happened to someone i knew before, turned out to be a stuck brake light switch. i played around with the switch and it finally popped back out and the lights turned off.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Tags
1996 , 2002 , 2004 , 95 , 96 , brake , civic , dx , fuse , honda , light , rear , removal , switch , tail
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
