Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-13-2009   #1 (permalink)
Blackhole4Ever
New Member
Blackhole4Ever is an unknown quantity at this point
Yellow Airbag/SRS connector/wire under seats - how to disconnect?
Probably a stupid question, and did some searching on here to no avail. This thread says something about it being spring-loaded:
Complete DIY write up on aftermarket steering wheel installation
Anyway, I cannot see an obvious way of disconnecting it (like the gray seat belt connector next to it) and was wondering if anyone could help.
Thank you...
Blackhole4Ever is offline   Reply With Quote
Sponsored Links
Old 06-14-2009   #2 (permalink)
Rudy
Member
Rudy is an unknown quantity at this point
Re: Yellow Airbag/SRS connector/wire under seats - how to disconnect?
That center widest part is the key. Pretty sure you pull up, but might need to push down - can't remember exactly.
__________________
Don
Sound Deadener Showdown
Rudy is offline   Reply With Quote
Old 06-14-2009   #3 (permalink)
bigaudiofanatic
Member
bigaudiofanatic is an unknown quantity at this point
Send a message via AIM to bigaudiofanatic
Ya what he said make sure your ground is off your battery before taking it off.
bigaudiofanatic is offline   Reply With Quote
Old 06-15-2009   #4 (permalink)
Blackhole4Ever
New Member
Crap, I didn't even know that moved. I thought that was just part of the overall fixed female end of the connector. It is spring-loaded, I guess.
You are right - just pull that forward and the male end just pops out. I've updated the picture and circled that to clarify things.
Also, I don't think it's necessary to disconnect ground -- just don't put the key in the ignition while it's disconnected or else you'll have to reset SRS (paper clips/key in ignition sequence), I believe.
Thanks...
Old 06-15-2009   #5 (permalink)
Running Riot
Senior Member
Running Riot's Avatar
Running Riot will become famous soon enough
Send a message via AIM to Running Riot
just break it off. gorilla glue it back together after.
__________________
B16 10.4:1 JDM Pistons ITR Manifold 70.2mm Throttle Body Skunk2 Stage 1 Pro Cams AEM FPR DC Header Magnaflow Custom 2.5" exhaust BDL Fuel Rail Nology Individually Grounded Wires Fidanza 7.5lb Flywheel Exedy Clutch Goodridge Braided Steel Clutch Line Fidanza Short Shifter Skunk2 knob JUN Chip
IM SO JDM I EVEN HAVE SARS
Running Riot is offline   Reply With Quote
Old 06-15-2009   #6 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
ya those clips are a bit backwards in how they disconnect. and battery can stay connected in almost all cases, thats just a precaution.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 06-15-2009   #7 (permalink)
Running Riot
Senior Member
just do what i did when i took my air bag system out, wear a helmet and hope for the best.
__________________
Tags
civic , honda , srs , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
