Honda Civic Electrical, Wiring, and In Car EntertainmentThere's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
UPDATE: The cause of the problem was I didn't slow charge the cap, I didn't put the resistor in. We now know why I have the problem, we only need to find the problem!
Please let me begin by saying EVERYTHING in my system has been either changed or replaced.
I had this kickass system, it sounded amazing. However I was getting a slight headlight dim. So I got a Tsunami Competition Capacitor.
I followed the instructions and hooked it up. (This was verified by a pro audio shop ass being correctly hooked up.) I reconnected my battery and my cap began to squeal, it then blew my 150amp inline ANL fuse. I quickly disconnected it and started my car.
Ever since that incident I have gotten static and squealing (that matches the revs) out of my tweeters. It also seems to have weakened my whole electrical system. My lights dim while rolling the windows down (even with my sound system off). My lights also dim much more than they used to while the woofer hits. The tweeters also output the sound of the CD spinning in the headunit.The problem only exists while the engine runs.
This is not your common alternator squeal. I have tried everything I can think of.
Since the incident I have tried changing all of the following:
Head unit
Spark plugs
Amps
Speakers
4 gauge Ground wires
4 gauge Hot wires
Shielded RCAs
Remote wires
ELD
Head Unit Harness
Spark Plugs
Alternator
Battery
I have also tried:
Regrounding both my head unit and amp straight to the battery
Power the head unit and amp straight to the battery
Run the power on the seperate from the RCAs
Tried 4 different head units
Ground loop isolators
Ground Noise suppressors
Upgrading to 120Amp Alternator
Upgrading my battery ground terminals
The only thing that seemed to provide a band aid solution is on my Pioneer, if I touch the RCA ground to the headunit, the problem completely goes away. This does not seem to work on the Sony, Alpine, nor Pyle head unit.
Please I am begging for someone to figure this out. This was originally posted at CivicForums, but so far no one has solved it.
I have grounded the headunit and amp straight to both the battery and chassis which made very little difference. I have also powered the head unit straight from the battery. I've also replaced the battery tap for the ground with brand new thicker gauge wiring, as well as the ground going from the engine to the chassis.
not likely. just to be sure, you ran the rcas and power wire for the amp on opposite sides of the car right? its possible your rcas are just crappy quality and are picking up noise, or they got ruined when you hooked the cap up wrong. does the static happen when you have stereo on but engine off? could be the "hotwires" which im assuming are the nology spark plug wires. they dont really do anything, but the caps in the wires may be causing interference.
__________________
Restore Performance, Reduce Costs www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
The cap is currently out of the system in fear that it my "mess" something up further. The RCAs are shielded "Competition Series" and they are indeed ran separate from the power. I have also tried a brand new RCA cable not hidden or anything just running over the center console.
I am a computer person, I thought the transition to car electronics would be an easy one... ahahah
I am also trying to read up on the ELD, could that be a possibility?
I have also pulled the fuse for my alternator and started the car for a quick sec, the static was pretty much gone, however the engine sequel in the tweeters continued.
Thank you gearbox for taking more interest in this subject than anyone before you My father works for a Honda dealership (Not a technician, but he has no clue).
hmm i dont know what else it could be. unless, you blew the diodes in the alternator with your cap accident. that would cause alot more electrical noise. its also possible you blew the resistors in the spark plugs, or both. the ELD is just the electronic load detector, it senses how much power the car needs and turns the alternator on/off accordingly so its not constantly producing power thats not needed.
__________________
Member 1025782
Ah. Well the noise is very noticeable, but if I crank the radio and fill the car with sound you cannot really hear it. It becomes only slightly louder when the volume is turned way up. The noise is only present when the engine is running. The car seems to be much more sensitive to power as well. Even when the amps are unhooked, if I put the windows up or down my headlights dim, if I turn my headlights on my heating fans slow. The headlights were changed but they are still halogens (Low beams: Nighthawk Sport) (High beams: Regular Nighthawk)
the dimming and stuff is normal, our alternator is only 70 amps afterall, barely enough to run the car without accessories. the alternator may still be working but if the diodes blew, it will not dampen the electrical noise normally produced. try changing the spark plugs, then go to an auto store and have them check the alternator to see if the diode is good.
__________________
Member 1025782
Okay the doc is in. Here is what you have pioneer head units are known for the week rca grounding. So here is what you are going to do. Your going to take pieces or wire dosent matter if its 14 gauge or 16 gauge. And you are going to wrap a piece around your "grounding screw" than the other part you are going to wrap around the rca plugs. This should get rid of your noise. I could go into massive details on why this happens but I am not.If it still a curs after doing this than I might have to make an on site appearance. Here is a pick on what I am talking about.
It dose not hide the problem. If you were to go buy a alpine head unit and install it you would not have this problem. The fact as I stated is that all pioneers have week grounding points on there rca's thats why you are getting the noise if they have a better ground than it will go away. This is what you have to do. Belive me I use to have a ppioneer in my 1999 honda civic and had the problem I didn't want to do that wire trick becasue I though it was a stupid to try but it works. But I got smart and found out that alpines are better so I went with them.
I am currently using a Pyle because my Pioneer died and is out for repairs. I have the same problem with a Pyle, I also tried another headunit which was a Sony with the same problem. The problem introduced itself with the bad cap install, before that my Pioneer and all my other head units worked really well.
Hmm looks like I may need to come there. Try a few other things. But also pyle and sony not to rude but are rely rely cheap brands so try that trick. Also try removing the cap and cleaning up your ground for your amp.RCA cable quality has nothing to do with the noise signal that is carried threw it and than amplified by the amp. So it usually is the head unit.
Believe me I use to run into problems like this and didn't know what to do. Now I do and I help people with the problems. I can tell you its not your alt or your spark plugs. If it were you would hear hearing an even more horrendous sound coming threw your speakers. Also were are your rcas? If they are on the same side as your power and wake up line move them to the other side of the vehicle.
