Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-09-2009   #1 (permalink)
imanoob
New Member
imanoob is an unknown quantity at this point
2001 Honda Civic EX electrical issues
Hello, I have very little experience with cars so I'll just describe the problem as detailed as I can. I have a 2001 Honda civic EX, standard transmission. A couple weeks ago while driving on the freeway, the SRS light turned on, then the ABS light came on, then the radio light started to shutter until it turned off entirely, then all the meters shut off on the dashboard and went to zero, or empty etc. but the engine still worked. The longer i drove the more lights would turn on, such as the brake light, the check engine light, while the headlights would dim. However if i would slow down to a certain speed the warning lights would turn off and the meters would turn back on. I had the car checked as far as the battery and alternator goes, and according to autozone the alternator was fine, but the battery was about to kick the bucket so I went ahead and bought a new battery and the car was fine for about a week. Now the same problem began with the ABS light coming on, then the SRS etc. except the meters never began to function again and more and more lights on the dashboard turned on, the cruise control light, the check oil light, and others until i could no longer accelerate and the power steering went out. I have no idea what the problem is and I would greatly appreciate any help or advice you can offer so I don't get screwed over if i have to take my car to an auto-repair shop. Please let me know what I can do to fix this problem. Thanks. To remove this ad, register today for free or log in if already registered!
imanoob is offline   Reply With Quote
Sponsored Links
Old 02-09-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: 2001 Honda Civic EX electrical issues
sounds more like alternator to me.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 02-10-2009   #3 (permalink)
[H]ashlee[H]
New Member
[H]ashlee[H]'s Avatar
[H]ashlee[H] is an unknown quantity at this point
Send a message via Yahoo to [H]ashlee[H]
Quote:
My car had that same problem over the summer. i also took it to autozone to have the altenator tested and it was fine....bought a new battery and it was fine for about a week or so then wound up having to jump start my car anytime i wanted to go sumwhere...all the lights were going nuts and the car was acting possessed...lol
but you may want to take your car to someone who knows all about the wiring in and around the motor and battery area. that was the problem with mine. the guy i had bought it from wired the whole car wrong which after a while caused it to go all bipolar on me. so i know a few ppl if you dont who can fix that problem in like ten minutes or so for a little of nothing.....no need in takin it to a shop to spend an a** load of money.
__________________
ashlee
[H]ashlee[H] is offline   Reply With Quote
Old 02-10-2009   #4 (permalink)
imanoob
New Member
Hi ashlee, thanks for the response. I'm not sure if the problem is how the car is wired because i bought it straight from the dealership, even though the problem might still have to do with the wires and such. I live in Glendale, AZ so if you know people or auto shops that you'd recommend around that area I would very much appreciate it, I'd certainly like to avoid the a**load of money option. Also, if you don't mind, I was wondering how much I should expect to spend on this type of repair. Thanks again.
Old 06-02-2009   #5 (permalink)
VtechXavi
New Member
VtechXavi is an unknown quantity at this point
i as well have a 2001 honda civic ex standard and i also have the same issues. Though my car has not died or my power steering failed i am having the lights come on should i probably go get my car checked out?
VtechXavi is offline   Reply With Quote
Old 06-02-2009   #6 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
yes of course. Its probably an alternator problem as gearbox has already stated.
04 Honda Civic is offline   Reply With Quote
Old 06-20-2009   #7 (permalink)
[H]ashlee[H]
New Member
im not quite sure about the Glendale area. i am from KY. i can give u the number to 2 guys who could probably let u know whats goin on....
even from the dealership, things can still be wrong. that is their common means of making money unlesss u were lucky and got a trustworthy one lol.
but believe me when i say that is part of the problem. also check ur fuses if any of them are blowed it could send current to the working ones and cause them to go bipolar-ish on ya then eventually blow those as well.
and with my guys u aint spending over $100.00 for any of this.
__________________
ashlee
Old 06-24-2009   #8 (permalink)
2k1_Toaster
Member
2k1_Toaster will become famous soon enough
I had the same problem. Alternator was fine, battery was good. Charge the battery and everything was good until it ran low and eventually the car would shut off and die from no power.
Turned out to be a loose cable. The connection between the big cable from the engine-area to the battery was not completely tightened to the terminal. So the alternator was working, but nothing was charging!
Something simple to check. Cost me $95 to find that out at the stealership...
__________________
2k1_Toaster is offline   Reply With Quote
Old 07-02-2009   #9 (permalink)
[H]ashlee[H]
New Member
while your stuff costed you a whole new butt hole mine costed me zilch......
__________________
ashlee
Tags
2001 , 2004 , civic , crv , dashboard , driving , electrical , honda , lx , problem , problems , radio , shuts , turned , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
