| Re: Garmin StreetPilot question Found this on Garmin's site:
Question: Why won't my StreetPilot c3xx power on?
Answer:
If your StreetPilot does not power on, or if it turns on then turns off, you can troubleshoot the problem by resetting or charging the unit. The reset is a "soft" reset that you can perform in the car; it restores power to the unit, but it does not remove data.
To reset the unit:
1. Place the unit in the cradle and roll it backwards slightly to lock it in place.
2. With the key in the car ignition, turn on the unit or put it in accessory mode.
3. On the face plate of the unit, put your thumb nail in the groove under the Garmin logo and gently pull off the face plate.
4. With the face plate removed, press the reset button on the right side.
5. Turn the unit back on. If the unit still doesn't power on, you may need to charge it.
To charge the unit:
1. Using the provided USB cable, connect the device to the computer.
2. Reset the unit (following instructions above).
3. Keep the device connected to the computer and allow it to charge overnight (7-8 hours).
4. After charging, unplug the unit and power it on.
__________________ MECP Master
ASE Electrical
Mobile Tech Support Specialist
BBY Corporate My 01 EX coupe |
