Honda Civic Electrical, Wiring, and In Car EntertainmentThere's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
2003 instrument panel reseting when car turned off: [SOLVED]
I had this problem with my instrument panel going back to odometer readings every time I turned the ignition off. I was also having problems where my car alarm would unlock doors fine, but wouldn't lock them. My car is a hybrid so the IMA light also went on.
It turns out the culprit was ol' fuse #9 the 10 amp fuse located in the compartment under the hood.
I just thought I would post this in case someone else is having the same symptoms and can't figure out the solution.
