| Re: HELP: Cealing/Dome light Another good low current source for this application would be the ignition illumination source (the light is only on EX models but the wiring is present on my 05 LX) The wire colors are WHT/BLU for +12 Volt source and WHT/BLK as the control wire. (WARNINGS... Those column covers SUCK to remove, you most likely will break the tabs. This source was only made to drive a single LED, I would not attempt to drive much more than some LEDs from it.) |
