Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Reload this Page
Interior courtesy lights fuse
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
LinkBack Thread Tools
Old 10-04-2008   #1 (permalink)
grmhonda
New Member
grmhonda is an unknown quantity at this point
In my 2006 Civic 2-dr coupe the fuse that controls the interior lights (map, dome, trunk), continuously blows. Replaced fuse (7.5 amp) and it either works for a short period of time or the fuse shorts as soon as it's plugged in. All other fuses work fine. Any ideas as to where to start looking for short or any ideas on what could be the cause??
grmhonda is offline   Reply With Quote
Sponsored Links
Old 10-04-2008   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
Re: Interior courtesy lights fuse
gotta retrace the wiring, maybe one is shorting out. is the car stock? or have you installed stuff at all.
gearbox is offline   Reply With Quote
Old 10-04-2008   #3 (permalink)
grmhonda
New Member
Thanks for the reply. No, haven't installed anything. Car just has factory-installed equipment.
Old 10-06-2008   #4 (permalink)
electric130
I.C.E. Mod
electric130's Avatar
electric130 should not be questionedelectric130 should not be questionedelectric130 should not be questionedelectric130 should not be questionedelectric130 should not be questionedelectric130 should not be questionedelectric130 should not be questionedelectric130 should not be questionedelectric130 should not be questionedelectric130 should not be questionedelectric130 should not be questioned
probably have something grounding out. no easy fix here. you've got to start chasing wires, disconnecting portions to isolate parts of the circuit, etc. no small task
electric130 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Front Door Speaker Help (with pics!)
Replacing stock speakers
Post pictures of your trunk speakers!
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Sub box dimensions/theory
The new Pioneer Avic-D3!
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Should I upgrade battery or alternator first?
Is a power window conversion possible?
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
