Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Reload this Page
06 stock stereo won't eject CD
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
LinkBack Thread Tools
Old 09-29-2008   #1 (permalink)
BCool
New Member
BCool is an unknown quantity at this point
My girlfriend's got an 06 Civic (EX, IIRC) with 80K on the clock. The stock stereo worked fine until a couple weeks ago - now it won't eject the CD that's in there. It wouldn't even accept a CD for a little while, then she stuck one in there with some coersion but when pressing the Eject button now, it just makes some noises like it's trying to spit it out...but nothing happens.
I tried searching, but could only find posts with similar problems about aftermarket HUs. Anyone ever have this problem with the stocker? Any suggestions about what to do?
BCool is offline   Reply With Quote
Sponsored Links
Old 09-29-2008   #2 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Alpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questioned
Re: 06 stock stereo won't eject CD
I suggest getting an aftermarket piece.
Then start taking the OEM apart to retrieve your cd..
Alpha 5 is offline   Reply With Quote
Old 09-29-2008   #3 (permalink)
BCool
New Member
That was my suggestion as well; it quickly got shot down. I had to fight with her to even agree to let me maybe take the dash apart if I was able to find a cause... She definitely doesn't want an aftermarket HU though.
Old 09-29-2008   #4 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
why not, my stereo shop has them starting at $89.00 for nice Kenwood piece.
Then tell her she is stuck listening to that stupid cd for ever....
Old 09-29-2008   #5 (permalink)
BCool
New Member
idk why not...she's a woman, do they ever need a reason? :P
Seriously though, I'm well aware of the availability of inexpensive alternatives...she's just very stubborn about some things.
Old 09-29-2008   #6 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
how about search for a stock replacement on ebay. either way the dash is coming apart cause the one you have now is dead.
gearbox is offline   Reply With Quote
Old 09-29-2008   #7 (permalink)
BCool
New Member
Gotcha - I was just looking for confirmation (or not) that the stocker was, in fact, dead. I've already searched eBay and found one... I just didn't know if maybe this was a somewhat common problem, or if there was some simple "fix" I might be missing.
Old 09-29-2008   #8 (permalink)
DeX
Ultimate Member
DeX's Avatar
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Quote:
80K = 80 kilometres?
80K = 80,000 kilometres?
80K = 80,000 miles?
clock = odometre?
WTF? Internet grammar is getting way too prevalent. I had this happen to me before, I had to jam another CD in underneath that one, curl the new CD so it was pushing up on the stuck one and try to pull them both out together. When I finally got it out, I opened the window and ejected that CD permanently at 120 kilometres an hour (that's 120k for you shorthanders). The problem was from the headunit being made to work perfectly horizontal. But the Civic dash is pointed towards the ceiling a bit so it had to work harder against gravity to push the CD slightly upwards and out. This eventually led to its demise.
Or if it's anything like a CD-ROM drive on a computer, there might be a little tiny hole next to the eject slot and if you stick a paper clip in there, it's a manual eject for the disc.
DeX is offline   Reply With Quote
Old 09-29-2008   #9 (permalink)
BCool
New Member
80K = 80,000 miles?
clock = odometre?
Interesting set of options... My mistake - I haven't filled out my profile yet. I'm from the US, so I assumed that it would be understood. Typically, K = thousand, M = million, B = billion, T = trillion. 80 Kilometers would've been written as "80KM," "80 Km," etc. Again, since I'm in the US (didn't realize this was such an int'l (international) forum...which is great!), I assumed it would be understood that I meant 80,000 miles. Finally, yes, clock = odometer. Typical US gearhead ("car guy," etc) slang, if you will...not internet-speak at all. Actually, none of it is "internet grammar" at all - it's all common abbreviations. And, I actually used correct grammar, punctuation, capitalization, and sentence structure even!
Oh, and if internet grammar is getting way too prevalent for you, don't write things like "WTF"
Thanks for the tip about using another CD to "wedge" the old one out. I'd read that in a couple other threads; I'll have to try that to get the current one out.
Old 09-29-2008   #10 (permalink)
DeX
Ultimate Member
DeX's Avatar
Actually kilo is the latin abbreviation for thousand, lazy people just shorten it to K.....so basically they're abbreviating an abbreviation. It's like people who refer to a Civic as a 'Vic and then just deciding to call it a V.
Busted!
I used to live in the states for a year but there's a lot of us Canadian members here, sometimes gets confusing with the trim levels. You may also want to try removing the CD player, pointing the slot at the floor and hitting eject (while still powered). It'll likely spit it out with the help of gravity.
Old 09-29-2008   #11 (permalink)
BCool
New Member
Very true.
Seriously? That's aweful...lol...
I'll try that as well...thanks!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Front Door Speaker Help (with pics!)
Replacing stock speakers
Post pictures of your trunk speakers!
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Sub box dimensions/theory
The new Pioneer Avic-D3!
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Should I upgrade battery or alternator first?
Is a power window conversion possible?
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
