Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Reload this Page
Spark Plug Tick
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
LinkBack Thread Tools
Old 08-30-2008   #1 (permalink)
TeraCivic
New Member
TeraCivic's Avatar
TeraCivic is an unknown quantity at this point
Spark Plug Tick
I just put in a new amp in my 03 civic ex and i have all the wires separated the power on one side and preamps on the other and i have a tick from the spark plugs and as far as i know they are the same ones the factory put in how would i fix this problem could it be the spark plugs doing it or something else
TeraCivic is offline   Reply With Quote
Sponsored Links
Old 08-30-2008   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
Re: Spark Plug Tick
what does it sound like, ticking from speakers? you gotta make sure the factory grounds are tight and connected to bare metal, then run a new ground and power wire from stereo to battery. do not use stock factory harness for power and ground! also make sure your amp is properly grounded to bare metal.
gearbox is offline   Reply With Quote
Old 08-31-2008   #3 (permalink)
TeraCivic
New Member
TeraCivic's Avatar
Re: Spark Plug Tick
my amps are grounded to bare metal the radio is using the factory harness i'll try connecting it to the same as the amps thanks
Old 08-31-2008   #4 (permalink)
TeraCivic
New Member
TeraCivic's Avatar
Re: Spark Plug Tick
it didnt work
Old 09-01-2008   #5 (permalink)
gearbox
Super Moderator
Re: Spark Plug Tick
are you using resistor style spark plugs?
Old 09-01-2008   #6 (permalink)
TeraCivic
New Member
TeraCivic's Avatar
Re: Spark Plug Tick
they might be they are the factory plugs so if i get different plugs will that help
Old 09-03-2008   #7 (permalink)
gearbox
Super Moderator
Re: Spark Plug Tick
factory plugs are resistor, actually most you can buy are these days to cut down EMF interference. idk what else it could be. you sure the deck is okay?
Old 09-03-2008   #8 (permalink)
DeX
Ultimate Member
DeX's Avatar
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: Spark Plug Tick
it didnt work
How do you have 4 posts in one thread without a single piece of punctuation?
DeX is offline   Reply With Quote
Old 09-03-2008   #9 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
Re: Spark Plug Tick
valve adjustment?
02BLKCIVIC is offline   Reply With Quote
Old 09-07-2008   #10 (permalink)
TeraCivic
New Member
TeraCivic's Avatar
Re: Spark Plug Tick
Quote:
Originally Posted by 02BLKCIVIC View Post
valve adjustment?
wat valve
Old 09-08-2008   #11 (permalink)
02BLKCIVIC
02BLKCIVIC's Avatar
Re: Spark Plug Tick
what valve
the valves in your engine.
there are 12 of them.
and they tick when out of spec.
Old 09-08-2008   #12 (permalink)
Tragedy
skate or die
Tragedy's Avatar
Tragedy is a name known to allTragedy is a name known to allTragedy is a name known to allTragedy is a name known to allTragedy is a name known to allTragedy is a name known to allTragedy is a name known to all
Re: Spark Plug Tick
^yeah they do when they are off.
IMO the d17 is naturally a little loud on the valve / spark side.
Tragedy is offline   Reply With Quote
Old 09-08-2008   #13 (permalink)
lordhelmet
Super Member
lordhelmet's Avatar
lordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questioned
Re: Spark Plug Tick
What?
lordhelmet is online now   Reply With Quote
Old 09-08-2008   #14 (permalink)
Tragedy
skate or die
Tragedy's Avatar
Re: Spark Plug Tick
I guess he forgot about the VTEC valve.
Old 09-08-2008   #15 (permalink)
02BLKCIVIC
02BLKCIVIC's Avatar
Re: Spark Plug Tick
lol k
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Front Door Speaker Help (with pics!)
Replacing stock speakers
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Post pictures of your trunk speakers!
Sub box dimensions/theory
Install a new head unit into a 2003 civic
The new Pioneer Avic-D3!
Removing factory cd player from 2004 civic
Should I upgrade battery or alternator first?
Is a power window conversion possible?
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
