Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Reload this Page
Is there a sensor for the reverse lights?
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
LinkBack Thread Tools
Old 08-27-2008   #1 (permalink)
vtec_concept
Member
vtec_concept is an unknown quantity at this point
My reverse lights are not working,
I bought new bulbs but still nothing
so my next step is to locate the sensor for the reverse lights, is there a sensor ?
or is there a particualr fuse to search for
my car is an 01 honda civic w/ automatic transmission...
vtec_concept is offline   Reply With Quote
Sponsored Links
Old 08-28-2008   #2 (permalink)
CraigW
Diamond Member
CraigW's Avatar
CraigW is a glorious beacon of lightCraigW is a glorious beacon of lightCraigW is a glorious beacon of lightCraigW is a glorious beacon of lightCraigW is a glorious beacon of light
Re: Is there a sensor for the reverse lights?
There is a switch on the transmission.
Fuse #10 = 7.5 Amps in under dash fuse box.
Wire color for reverse lights circuit is GRN.
A possibility is the wire in the black plastic loom that moves when trunk is opened/closed may have broken. The loom has tape around it but can be opened. Locate the green wire inside up near the trunk and give the wire a slight pull to see if it moves. If it moves easy it is broken from flexing.
CraigW is online now   Reply With Quote
Old 10-01-2008   #3 (permalink)
DANGer905
New Member
DANGer905 is an unknown quantity at this point
Any luck with this issue vtec concept? I'm in the same situation, I have a 02 sedan and just recently noticed the reverse light not working. I'm not sure when it stopped working but recently I did just install a new head unit/car stereo. I took the necessary precautions and disconnected the battery for the install as well. First my right reverse only worked every now and then. I tried swapping the left and right reverse bulbs to see if the issue was with the bulb or wiring. When i first did the swap the bulb originally in the left was working when plugged in the right and the bulb originally in the right was not working in the left. I was happy thinking it was just the bulb but when i swapped them back now even the one that was originally in the left stopped working.
I haven't tried buying new bulbs yet because if the right reverse light is some how blowing out the bulbs I wouldn't want to put brand new bulbs in it and have it just kill it. Can any help us out on this? I've searched the forums and this post seems to be the closest match to my situation.
Any help is much appreciated. Thanks
DANGer905 is offline   Reply With Quote
Old 10-01-2008   #4 (permalink)
DANGer905
New Member
Went ahead and replaced the blubs with the standard 7440's anyways. So far so good. My reverse lights are back.
Old 10-01-2008   #5 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
mightve just been bad/old bulbs. ive had some fall apart for no reason. also there is a ground point under the cover that goes around the trunk latch. you may want to check that for corrosion.
gearbox is offline   Reply With Quote
Old 10-09-2008   #6 (permalink)
DANGer905
New Member
Thx Gearbox,
Everything is is running fine now, guess both bulbs just blew right about the same time. Oh just to mention, after reading your guide to auto lighting, I went and ordered myself a set of Philips x-treme power H4's from powerbulbs.com. They threw in some Philips blue vision w5w which was a pretty nice bonus. (For those to just stumbled on this page and are ordering from powerbulbs, use voucher code AYSCX1729=10% discount). Thanks for great guide gearbox.
Old 10-09-2008   #7 (permalink)
DANGer905
New Member
Just wondering what would be the best use for the Philips blue visions w5w?
Old 10-09-2008   #8 (permalink)
gearbox
Super Moderator
you can use the bluevision as plate lights, front park lights, or dome lights. anywhere that has 194 style bulb.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Front Door Speaker Help (with pics!)
Replacing stock speakers
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Post pictures of your trunk speakers!
Sub box dimensions/theory
Install a new head unit into a 2003 civic
The new Pioneer Avic-D3!
Removing factory cd player from 2004 civic
Should I upgrade battery or alternator first?
Is a power window conversion possible?
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
