| Re: SRS light on? Maint Req light on? For the airbag light, I'd try a battery reset:
Unhook negative battery cable, leave it unhooked for 20 minutes.
Unhook positive cable, touch the posi & neg cables together for a couple of seconds.
Hook both cables back up to battery. Cross your fingers.
As far as the maintenance light is concerned:
1. Make sure ignition is switched OFF.
2. Press and hold pushbutton to lower right of speedometer.
3. Turn ignition to ON (no need to start engine though).
4. Keep holding that pushbutton, after about 10 seconds the maint req'd light should clear.
5. Release button and turn ignition OFF.
__________________ MECP Master
ASE Electrical
Mobile Tech Support Specialist
BBY Corporate My 01 EX coupe |
