Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-25-2007   #1 (permalink)
Ashhole
Ashho-san 7thgen Ninja
Ashhole will become famous soon enough Ashhole will become famous soon enough
Send a message via ICQ to Ashhole Send a message via AIM to Ashhole Send a message via Yahoo to Ashhole
Rear speakers
Ok, i just installed some new speakers in my 01. They were some pioneer A6971Rs. They are in, and they work, but they are very quiet. I was wondering if i did somethign wrong with the install, if that may be just the way the speakers are.
I was wondering if it has to do with power output to the speakers. I'm currently using the stock CD player, and these speakers will take 300w. Will they work better when i get a new cd player? or should i look at a small amp for them?
__________________
1/4: 16.659
@: 82.61 mph
7th Gen Ninja #19
My Myspace
My Cardomain
DIY: Blacked out Altezza Tail lights
7thGen.MT.C.
Ashhole is offline   Reply With Quote
Sponsored Links
Old 02-25-2007   #2 (permalink)
rice4lyfe
Super Member
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
switch the leads, as in, switch the wires around. Common mistake
__________________
ssm sedan
rice4lyfe is offline   Reply With Quote
Old 02-25-2007   #3 (permalink)
Ashhole
so i shouldnt have connected the wires with the black lines from the speakers to the same ones from the car?
__________________
1/4: 16.659
@: 82.61 mph
7th Gen Ninja #19
My Myspace
My Cardomain
7thGen.MT.C.
Old 02-25-2007   #4 (permalink)
christmaspie
Super Member
christmaspie's Avatar
christmaspie is a glorious beacon of light christmaspie is a glorious beacon of light christmaspie is a glorious beacon of light christmaspie is a glorious beacon of light christmaspie is a glorious beacon of light christmaspie is a glorious beacon of light
Did you use a speaker harness for the install or just tap into the wires at the rears?
If you tapped confirm they agree with this:
left rear
+ blue/white
- blue/black
right rear
+ pink
- blue/yellow
If that is all correct it probably just isn't enough power for the aftermarket 6x9s.
__________________
MECP Master
ASE Electrical
Mobile Tech Support Specialist
BBY Corporate
My 01 EX coupe
christmaspie is offline   Reply With Quote
Old 02-25-2007   #5 (permalink)
rice4lyfe
Super Member
rice4lyfe's Avatar
there should be only 2 wires that you either cut and connected to the wires that came with your speakers
(in this case, just switch the wires around so opposite of what you have right now)
or
you used an adapter.
(you shouldnt have a problem here)
__________________
ssm sedan
Old 02-25-2007   #6 (permalink)
Ashhole
tapped the rear wires.
now for the speakers, the black/white and the whites are which?
__________________
1/4: 16.659
@: 82.61 mph
7th Gen Ninja #19
My Myspace
My Cardomain
7thGen.MT.C.
Old 02-25-2007   #7 (permalink)
rice4lyfe
Super Member
rice4lyfe's Avatar
they should only fit one on each side of the speaker output. Switch whatever combination you have right now
__________________
ssm sedan
Old 02-25-2007   #8 (permalink)
rice4lyfe
Super Member
rice4lyfe's Avatar
as in...where you tapped each wire, not the speaker connection
__________________
ssm sedan
Old 02-25-2007   #9 (permalink)
christmaspie
Super Member
White is likely positive and white/black is likely negative.
__________________
MECP Master
ASE Electrical
BBY Corporate
My 01 EX coupe
Old 02-25-2007   #10 (permalink)
drivlikustoleit
Senior Member
drivlikustoleit's Avatar
drivlikustoleit is an unknown quantity at this point
Send a message via AIM to drivlikustoleit
I got the same speakers (only in 6 1/2's) and they are very quiet as well and they are wired correctly. I have an aftermarket HU as well. I think we both need an amp.
__________________
If you're gonna do it, do it for yourself. If you're gonna say it, speak it for yourself. That way when it comes back to day one, you're your fvcking self.
drivlikustoleit is offline   Reply With Quote
Old 02-25-2007   #11 (permalink)
roll_outz
Member
roll_outz is an unknown quantity at this point
Well Prolly ur speaker is more watts than ur Oem deck.. or U can use volt tester to find out.it coz U $5 for the kit..Plan B U might need amps for better sound..gud luck dude..
roll_outz is offline   Reply With Quote
Old 02-26-2007   #12 (permalink)
electric130
I.C.E. Mod
electric130's Avatar
electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned
Quote:
yep to both of you. i put in some infinity reference 6012's and had to adjust the fade to make the front and rear level and i'm running an aftermarket HU with 52x4 output. almost any aftermarket speaker will sound weak unless you amp them.
electric130 is offline   Reply With Quote
Old 02-26-2007   #13 (permalink)
drivlikustoleit
Senior Member
Quote:
Given the specs I gave you in the sub box post for my after market HU and the specs for my speakers (my 6 1/2 are only 220W though) any good recmmendations on a decent amp that won't break the bank? I'm looking for better sound, not an award winning sound system.
__________________
Old 02-26-2007   #14 (permalink)
electric130
I.C.E. Mod
go with a cheap kicker 4 ch off ebay. you don't need much. 50RMS off an amp will be stronger than 50 off a HU.
Old 02-26-2007   #15 (permalink)
drivlikustoleit
Senior Member
Sounds good to me, I'll take your word for it. After that, I'm gonna start on my subs. Got my whole interior torn out right now... lot's of stuff is going on with the car here and there, lol. Thanks for the advice.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
