Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-22-2007   #1 (permalink)
rice4lyfe
Super Member
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
Adding in Map Lights?
Hey, just wondering if I were to buy a Map light from the EX's, would it fit into the area of my DX? Or are there kits I can buy to add Map lights?
Ideas are welcome.
Thanks
__________________
ssm sedan
rice4lyfe is offline   Reply With Quote
Sponsored Links
Old 03-05-2007   #2 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
You would have to buy the pieces from an LX beacuse I believe the map lights on the EX are intergrated into the sunroof assemby or something (I dont know, I dont have a ex). There is only one positive wire running up there to power them, pretty simple. The screw is used as the ground- which screws into a bracket thats welded on the roof. I'm sure there are ways you could do it, it woul dbe pretty simpled because the weight of the map lights is not a lot... grams at that. But the toughest part in my eyes would be mounting them to the roof (you probably could get a hold of someone that welds.. or take it to a muffler shop and have them spot weld a custom bracket that you made on there). You'd need some pics of what the EX assembly looks like for the map lights. I could take some for you, but I dont have my tools down there to take off my headliner. I'm sure you can find some, and if you cant, I'll be back home in a few weeks (last week of march is my spring break) and could snap them for you. Happy to help.
TRIZ is offline   Reply With Quote
Old 03-05-2007   #3 (permalink)
urwhat
Member
urwhat is just really nice urwhat is just really nice urwhat is just really nice urwhat is just really nice urwhat is just really nice
Send a message via AIM to urwhat
orrrrrrr... for another option. use leds with an external switch somewhere else.
i find factory map lights are way too bright. and useless in the dark for reading your mapquest directions or whatnot. i use 3 white LEDS mounted up top (mine is mounted on the cover for the mirror.. but i drive an rsx) so if you have something similar to mount it to up there, mount it there. then run wires down to a switch/fuse/relay(if you want, but its relatively low power consumption so switch+fuse should be fine)
__________________
AUDIO/VIDEO + CAR PARTS FOR SALE!
RSX TAN INTERIOR FOR SALE!
PM for details.
urwhat is offline   Reply With Quote
Old 03-06-2007   #4 (permalink)
rice4lyfe
Super Member
rice4lyfe's Avatar
hmm, well i wanted a stock look, but the LED idea sounds easy enough and is do-able. As for mounting the unit, i wonder if there is a bracket already installed on the body? Since its a unibody design, which is the same for all 7th gens (each sedan and coupe), i would assume that the mounts would still be there. I would just need to cut out wherever the headliner would be. If anyone is redoing their headliner with a DX or just someone with map lights (sedan preferably), please unscrew the unit and just snap a pic for me please! Thanks in advance.
__________________
ssm sedan
Old 03-06-2007   #5 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
I think the determining factor would be the design of the DXs headliner, Is the area where the map lights would go the same as LX or different ??
The map light assembly appears to be simply pressed into the headliners cutout opening.
The wiring may or may not be present as well.
CraigW is offline   Reply With Quote
Old 03-07-2007   #6 (permalink)
rice4lyfe
Super Member
rice4lyfe's Avatar
well the wiring i can bypass with either adding more and splicing or just splicing off the dome light. I was thinking that it was pressed into the headliner but its also screwed in, so if the bracket is also underneith, it would be even better.
anyone mind snaping a few pics? thx
__________________
ssm sedan
Old 03-07-2007   #7 (permalink)
urwhat
Member
well you cant even notice my LED's unless you really look for them. lets see if i have a picture...
found one... again this is in my rsx, not to get confused with anything else.
ID:	69990   Click image for larger version
__________________
PM for details.
Old 03-07-2007   #8 (permalink)
rice4lyfe
Super Member
rice4lyfe's Avatar
that looks kinda dim... does it manage to light up bright enough? I wouldnt mind it being bright, since thats why i need the light for.
Did you just pop off the cover and glue the LED's on?
__________________
ssm sedan
Old 03-12-2007   #9 (permalink)
urwhat
Member
the pictures dont do it justice since obviously theres brighter lights in the pictures.
the lights are bright enough to see mapquest directions anywhere in the center console area. If you want more light, simply add more LED's
i removed the cover, drilled holes, and used little LED holders that hold the led in place. no glue. best part is, you dont notice it unless you are really looking for it.
__________________
PM for details.
Old 03-14-2007   #10 (permalink)
TRIZ
TRIZ's Avatar
I dunno, if you wanted to go with that idea, I think you could get a led that focuses the light tightly and sink them in the cover a little better. Anyways. There is a bracket thats welded the the headliner. You should take a pic of your DX headliner- the area where the map lights would go, with the rear view mirror as a refereance point. I could tell you whats up then. You mgiht wanna go ahead and buy the LX headliner, i think it might be 50 bucks from majestic- or in that ballpark. It would probably make your life easier. the map lights themselves are about 1.5-2 inches thick, and thats not counting the bracket that they screw into. As for the wiring, its just a postivie 12v wire that comes up the drivers pillar. There is no ground wire that comes up, because the screw that holds the map light assembly to the metal bracket doubles as the ground. If you take off your headliner and peek under neath- you might have the bracket on there allready- I wouldnt be too suprised.
Old 03-15-2007   #11 (permalink)
rice4lyfe
Super Member
rice4lyfe's Avatar
ya, im pretty sure there is, as i said before, i dont think honda would make seperate body's just because of map lights. If anything, i could just take a template from another honda civic with map lights and cut from there.
I might attempt this in the summer time, when it gets a bit warmer. I just need a conformation that there is a bracket already there.
Anyone with a DX take off their headliner?
__________________
ssm sedan
Old 03-16-2007   #12 (permalink)
urwhat
Member
are you sure its a bracket though? map lights in my rsx is just attached directly to the roof of the car. theres just a threaded hole where you screw in the lights.
__________________
PM for details.
Old 03-17-2007   #13 (permalink)
TRIZ
TRIZ's Avatar
Its a bracket thats welded to the roof.
If you dont have a bracket, you might be able to pick one up from honda, instead of welding it on, epoxy paste to the rescue.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
