Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-23-2007   #1 (permalink)
disflipkevc702
New Member
disflipkevc702 is an unknown quantity at this point
Send a message via AIM to disflipkevc702
Spoiler light now working!?!?!?!
i was installing an amp and messing around with the wires in the trunk i guess, and next thing i knew, my spoiler light isn't working!?!?! i was looking for loose wires in the trunk and i found a wire with some plastic covering it, on the right side of the trunk attached to the right side metal support for the trunk... is that it? because it looked like it should be connected to something... or is there a fuse somewhere? To remove this ad, register today for free or log in if already registered!
disflipkevc702 is offline   Reply With Quote
Sponsored Links
Old 01-24-2007   #2 (permalink)
Taffy
Random Person
Taffy's Avatar
Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future
Hmmm that's weird, because you shouldn't even be near those wires if you were installing an amp. Your spoiler light should be connected with your third brake light, so make sure those are working also. Unwrap the black wire loom around the wires leading up to the spoiler light and make that none of the wire is cut or stripped, causing a short.
Good Luck
Taffy is offline   Reply With Quote
Old 01-24-2007   #3 (permalink)
disflipkevc702
New Member
which wire is the spoiler light?
Old 01-24-2007   #4 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
The OEM spoilers wiring goes into the top of the trunk on the passenger side mount. It uses the channels formed by the re-enforcement/support frame. It should come out near the passenger side hinge, (2 sets of wires in black plastic loom) It will then work its way to near center where the bulb used to be for the 3rd brake light in the back glass. A connection is made there that lights the spoilers circuit.
There will only be 2 wires in the one for the brake lights.
CraigW is offline   Reply With Quote
Old 01-25-2007   #5 (permalink)
disflipkevc702
New Member
i see, becuz the wire that was loose on mine was a wire with a gold terminal and a black plastic thing from one wire.. and it came loose to the right side of the trunk , not near the brake light or anything..
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Dash, panel, speedometer LIGHT not working. djdust12 Mechanical Problems/Vehicle Issues and Fix-it Forum 16 11-07-2006 01:31 PM
Fog light not working- need help damion Canada East 9 10-13-2006 02:10 PM
a/c light not working booba5185 Honda Civic DIYs and Civic Tech Chat 2 07-16-2004 07:00 PM
Low Fuel Light. Not working 2000IndigoX Honda Civic DIYs and Civic Tech Chat 10 06-02-2004 07:01 PM
3rd brake light not working velocity Mechanical Problems/Vehicle Issues and Fix-it Forum 3 07-12-2003 07:20 PM
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
