Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-23-2007   #1 (permalink)
Rufus
I drink Windex...it keeps me from streaking...
Rufus's Avatar
Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of
One channel cuts out...
Ok here's the setup and then I'll follow with the issue:
Equipment
2003 Honda Civic EX
Battery: Optima Redtop
0 guage from the battery to a dis. block then 4 guage to amps (300/2 and a 500/1)
HU: Alpine IVA-D901
Processor: PPI DCX-730
Amp: JL 300/2
Issue
After listening to music for awhile, I've noticed that one channel of the amp seems to cut in and out when bass hits. I can identify this as some sort of poor connection as it has gone in and out over bumps in the road. For a process of elimination, I've switched the RCA's coming from the processor to determine if the short would switch sides. It did not. Then I switched speaker channels by moving the right to the left and vis versa and the short DID move. So at that point I considered that the terminals were coming loose. I can attest to the fact that previous owner of my 300/2 did nearly strip the allen heads for that terminal, but when I give the wires a tug they seem fine and hold well. In addition, when the sound cuts in and out the volume goes up MUCH higher. I have the volume for the sound attenuated from the processor to reduce background noise and it's as if the processor isn't suppressing one channel. So what is it, the processor or the amp? Could it be the amp terminal or does it sound like an internal short? I have just redone all wiring into the car, and everything is clean and neat. I've never had a ground issue, and even if that could be a factor, how could it effect one channel? I called JL once and they tried telling me it was due to a low output alternator. I've had this setup for years and this issue just recently came about, so I'm reluctant to believe that. Suggestions?
As a side note, I'm going to go straight from the HU to the amp tonight to try to remove the Processor from the equation and see if the issue still exists..
Rufus is offline   Reply With Quote
Sponsored Links
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Eng cuts out at 4k. chamberlain_069 Mechanical Problems/Vehicle Issues and Fix-it Forum 7 10-27-2005 08:37 PM
Hot Cuts pbfoot Off Topic 40 05-31-2005 12:42 PM
do you know anyone who cuts themself? dirtySAMURAI Off Topic 30 03-23-2005 02:41 PM
sound cuts out jmythngdmb I.C.E. & Electrical 2 06-04-2002 03:09 AM
Is there any reason to get a 5-channel amp over a 4-channel? Brian I.C.E. & Electrical 5 02-06-2002 07:31 AM
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
