Go Back   Honda Civic Forum > GENERAL > Honda Civic Electrical, Wiring, and In Car Entertainment
Honda Civic Electrical, Wiring, and In Car Entertainment There's no limit when it comes to in car entertainment for your Honda Civic. It takes experience to make a car for show or even your average car audio enthusiast. Get the information needed to work on your Honda Civic Electrical Wiring and I.C.E.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-11-2007   #1 (permalink)
Punkrulz
New Member
Punkrulz is an unknown quantity at this point
Problems with rear-windshield integrated antenna
Hey guys,
I have a 2005 Civic EX with the windshield integrated antenna. Lately I have been having numerous issues with the quality of Audio I've been getting from it. I live in the Philadelphia area, maybe about 5 minutes away. Sometimes I turn my car on, turn my audio on, and get crystal clear audio... other times I turn it on, and get nothing but static on every station.
Today was the biggest culprit. In the morning, audio was fine for my philly channels, but I was travelling from 5 miles away to about 45 miles away without a problem. Then when I turn my car on down here (About 10 minutes from Atlantic City), I got nothing but static... I hit the scan button, and first it found one channel that was from this area, but it was staticy and scan couldn't find it again. Ate lunch, went back to my car, turn the car on and my Philly channels are back to being perfect again. Some people have recommended that this may be the cause of a loose antenna wire, however I have to disagree. While driving around, it isn't like my stereo has good quality, then bad quality. If it works when I turn it on, then it's good the entire way. If it's static when I turn it on, then it's static the entire way.
What gives?
Punkrulz is offline   Reply With Quote
Sponsored Links
Old 01-12-2007   #2 (permalink)
Ed
Ultimate Member
Ed's Avatar
Location: Deathie Elaine and Pecosa Land, Hudson, Ohio, US
Ed will become famous soon enough Ed will become famous soon enough
Send a message via AIM to Ed
Have you done anything to the HU lately? I'd suggest checking that antenna wire again, I don't know what else could so directly affect radio reception. Sorry, not much help here.
Ed
__________________
Signatures are for crazy people.
Ed is offline   Reply With Quote
Old 01-18-2007   #3 (permalink)
Punkrulz
New Member
I haven't touched anything with the car, I've never even taken the radio out, not really about to either... it just happened one day.
Old 01-19-2007   #4 (permalink)
4Saris
Senior Member
4Saris's Avatar
4Saris is an unknown quantity at this point
Is it a factory stereo?
4Saris is offline   Reply With Quote
Old 01-23-2007   #5 (permalink)
Punkrulz
New Member
Yep, never been removed from the car!
Old 01-23-2007   #6 (permalink)
4Saris
Senior Member
4Saris's Avatar
There went my theory.
Old 01-27-2007   #7 (permalink)
Hydro
New Member
Hydro is an unknown quantity at this point
sounds like the signal booster is screwd up. it's located in one of the rear pillers under a small access panel
Hydro is offline   Reply With Quote
Old 01-27-2007   #8 (permalink)
electric130
I.C.E. Mod
electric130's Avatar
electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned
i'd still pull the HU out and check the antenna wire. it may have vibrated loose. highly unlikely, but possible. maybe it didn't get installed all the way and has worked itself loose. i'd check the easy, free options before you have to buy anything to fix it.
electric130 is offline   Reply With Quote
Old 01-28-2007   #9 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Your antenna is the few strips that run across the top of your rear window-- they blend in with the defroster lines, but they have a dif pattern- you'll see.
Anyways, the rear passanger pillar panel is where your FM modulator is located. there is some 5 inch by 1.5 inch (aprox) piece of plastic that comes out with a little prying. Remove it if you want, your goal is to remove that whol pannel. Its held in my a few clips and are easily removed with a pull. I think there may be three. I take my panel off all the time and its just a tug, there isnt anything your going to break so just use a little finger grip and get it off.
That black box is the FM modulator. Inspect it for any broken or loose wires, and also look at the point it connects to the window. Something might have happened that made it f'd up.
Hopefully you'll find your problem.
To put the panel back on, fit it in at the bottom first, and then press it against the side of the pillar to pop the clips back in.
gl
TRIZ is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Problems with the rear-windshield integrated antenna? Punkrulz Mechanical Problems/Vehicle Issues and Fix-it Forum 5 12-20-2006 02:11 PM
2004 honda civic lx - brake problems & windshield gasket fraying lastV8intercptr Introduce Yourself! 0 09-23-2006 10:53 PM
Spots on rear windshield. Nyte Mechanical Problems/Vehicle Issues and Fix-it Forum 11 08-17-2006 11:18 AM
Can I trust a 22+mm bar with a non integrated reinforcement? Boilermaker1 Suspension Performance 15 07-15-2004 04:49 PM
still have problems with antenna range jvinson154 I.C.E. & Electrical 7 11-07-2003 03:39 PM
User Login
Our Partners
used new
Top 10 Threads
How to remove the dash trim on a 2003-2005 Honda Civic Si?
Front Door Speaker Help (with pics!)
Replacing stock speakers
Install a new head unit into a 2003 civic
Removing factory cd player from 2004 civic
Is a power window conversion possible?
Installing Fog lights
Post pictures of your trunk speakers!
2005 Honda Civic stereo wiring question (specific)
The new Pioneer Avic-D3!
Site Supporters
aluminum radiator
Honda car spoilers
