Relocated battery
Old 08-28-2016
Ppace52's Avatar
Ppace52 is an unknown quantity at this point
Relocated battery
Hey guys I'm new to this but I was relocated my mom's battery from her 2002 Ford Explorer to the trunk and for some strange reason my ground wire it's getting really warm and I'm using the same negative battery terminal that was original with my car. Should I get a thicker gauge wire it is it something else? Any suggestions or opionions on what I should do?
And I have a 1995 Civic DX by the way
Old 08-28-2016
Re: Relocated battery
How hot, and under what conditions?
If it gets much hotter than the pos cable thats not good IMO.
If one end or the other gets hot that's a bad connection that needs fixed.
If the entire cable gets hot then it needs to be heavier, go down a gauge size or two.
Old 09-05-2016
Dr Krieger of Modification
mac25's Avatar
Be careful!
It could get worse and lead to an electrical fire.
I'd say to set it back to stock.
Old 09-11-2016
patruns's Avatar
patruns is an unknown quantity at this point
You can't use the same gauge wires if you move the battery from the front to the back. The farther current has to travel the thicker wire you need. I would put it back.
OptimisticWay
01-03-2016 07:54 AM
rford65
11-22-2015 11:22 AM
bth Go Army
12-20-2001 06:36 PM
brill
11-16-2001 10:03 PM
onelifetolive
Bolt-on Engine Performance
11-10-2001 10:58 AM
Quick Reply: Relocated battery
