Notices
Wheels and Tires Post your wheel and tire related questions here.
Wheel hub ring size?
Old 07-10-2015
Genyc07's Avatar
Genyc07 is an unknown quantity at this point
So I buy stuff used and one of my favorite things to buy for my 2000 ex coupe are wheels some are aftermarket while others are Honda/Acura but none of the used wheels I purchased ever came with the plastic hub rung that goes between the rotor and the wheel. I searched and they are pretty cheap to buy but I'm not sure where to measure to get the right size for my applications. Currently I have 14inch Acura ls snowflakes for snow tires and have a set of motegi 17 inch mr7 wheels that I run in the summertime. Anyway just figured IDE ask u guys thanks.
Old 07-10-2015
Re: Wheel hub ring size?
You measure the bore of the wheel where the ring has to fit, and measure the flange of the cars hub where the ring has to fit.
Metric Digital Caliper is probably best to measure with. To the nearest 0.1 mm.
http://www.justforwheels.com/index.j...sub=searchsize
http://acurazine.com/forums/tires-wh...easure-858917/
Contact the wheel manufacturer and ask them? Website? Maybe Tirerack?
Old 07-11-2015
Genyc07's Avatar
Sweet links that's huge help!
09-26-2023 06:44 PM
Theshwartz35
07-17-2015 11:13 PM
muttleytm
07-11-2015 06:00 PM
muttleytm
07-08-2015 04:13 PM
BootyDo
07-07-2015 06:06 AM
Quick Reply: Wheel hub ring size?
