Not Coopers?
Has the rear camber problem been fixed?
Wheel bearings are ok?
I can't tell you what to get, but I can tell you some stuff to look for or avoid:
Do not choose directional tread.
Do not choose asymmetrical tread.
Choose symmetric tread pattern, this allows more servicing options.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=180
Choose a quality tire.
Choose a tire that does not have a large blocky tread pattern on the outer edges.
Huge cubes on the edges lead to chopping.
Finely sliced small blocks on the edges are preferable.
Probably a touring tire, not a performance tire.
Blocky tread is bad, these would probably get noisy in 10k:
Better design choice IMO:
Rotate tires religiously on schedule.
Almost any tire can get noisy if ignored and abused long enough.
HTH
