Notices
Wheels and Tires Post your wheel and tire related questions here.
Vibration/Shutter while turning
Old 10-30-2012
zackbmiller's Avatar
zackbmiller is an unknown quantity at this point
Question Vibration/Shutter while turning
Hey forum! First time posting here, glad to find a nice civic forum.
The past few days, I've noticed a pretty nice vibration/shutter when I make left hand turns. I feel it slightly in the right hand turns, but not nearly as much in the lefts. I AM due for an alignment. I'm hoping that this is the cure to my problem, but I want to be sure.
I've jacked my car up, checked for play in both tires, both are fine, so I'm sure the bearings are still good. I've replaced both half shafts and brake pads about 15k miles ago. My suspension seems to be fine when I apply weight to the front of the car.
Just a concerned honda owner that wants to keep his car ticking
Any help/suggestions would be greatly appreciated!
Below are few pictures.
Front
Top Front
Rotter and break pad
Behind the wheel assembly
End of half-shaft
Spring
I will keep the car jacked, so if I need to take any other pictures or pick apart anything, I can.
Again, thank you all!
Old 11-01-2012
Re: Vibration/Shutter while turning
Update: After my father and I looking at the car, we found that the tire and/or the rim is causing this problem. Once I replace the rim, the tire, and get an alignment, I will let you all know how it went.
Old 12-05-2012
Gilbert991's Avatar
Gilbert991 is an unknown quantity at this point
Hi all i think you want to repair the shaft and spring and these two part are looking damage in these pictures.
Pir8pete
165
03-06-2009 05:16 PM
wawacito
05-14-2002 07:33 PM
my2k1vic
01-08-2002 08:31 PM
CapYoda
01-07-2002 03:20 PM
blackbullet
12-01-2001 03:44 PM
Quick Reply: Vibration/Shutter while turning
