Honda Civic Wheels, Tires, & BrakesHow underrated these parts can be when properly upgrading your Honda Civic to a true sports machine. Wheels, Tires, and Brakes for your Honda Civic can change the way your car looks, acceleration, and stopping distance.
Welcome to civicforums.com!
Welcome to civicforums.com.
For the past little while I've noticed my brake power has decreased dramatically.. to the point where I have to press really hard on the brakes in order to actually stop.
When I press on the brake pedal when slowing down from a good speed, I can feel a pulsing (both in the pedal and in the actual feel of the car)...
I think I've got a warped rotor or perhaps uneven wear or something. Would a warped rotor decrease braking power? Or would I need new pads as well?
Help
Sponsored Links
Yes, sounds like you need both, perhaps pads and resurfacing or new rotors. when was the last time u change ur pads and whats ur mileage like...
+1
You can visually check them both to see the condition. If you can barely see your pad then there is your answer there. As for the rotor look to see if you can see any funny lines. That'll give you an idea of the condition of the rotors. Most likely you'll have to replace both.
also do u hear noises like metal squeeking or scratching when u brake or under normal driving? even with worn pads your car can still brake, but like you said u might have to press it down harder and of course it wont be as strong, but have someone look at it if you dont know what you're doing.
