Go Back   Honda Civic Forum > GENERAL > Honda Civic Wheels, Tires, & Brakes
Honda Civic Wheels, Tires, & Brakes How underrated these parts can be when properly upgrading your Honda Civic to a true sports machine. Wheels, Tires, and Brakes for your Honda Civic can change the way your car looks, acceleration, and stopping distance.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-28-2009   #1 (permalink)
Laycox
New Member
Laycox is an unknown quantity at this point
Cool replacing pads & rotors on 2006 - any tips
Hello all
Wow - there is inforamtion overload on this forum - good stuff and some of it confusing
I need to replace the rotors ( I know these can be cut - turned but hey time is Money ) and pads on a 2006 civic
First question - I have the parts and want to make sure I have the correct tool for removing the Caliper "pins" from what I have read this is a 12 mm allen - correct ?
Second - there are comments on disconnecting ABS before starting to compress the caliper - true or false -? what if you do not ?
Third question - software updates for "warped rotors" if I am replacing these is this an issue ? Do you need to "calibrate" to new rotors
Always been a "back yard mechanic" mostly on Domestic -Civic is new for me any help / clarification is appreciatd
Regards and Thanks
Paul
Laycox is offline   Reply With Quote
Sponsored Links
Old 09-29-2009   #2 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
Re: replacing pads & rotors on 2006 - any tips
Getting your rotors turned is usually worth it. You dont need to calibrate anything on them. If they are too thin the man at the shop will tell you. Aftermarkets are cheap so not many people turn rotors anymore.
04 Honda Civic is offline   Reply With Quote
Old 4 Days Ago   #3 (permalink)
Seabee
New Member
Seabee is an unknown quantity at this point
Don't turn your rotors they will just warp again. with less metal on the rotor they will heat up faster and warp faster.
Get the EBC slotted rotors form www.horsepowerfreaks, and a set of OEM pads.
And make sure to lube the slide pins so they move freely.
hth
Seabee is offline   Reply With Quote
Tags
2006 , 2007 , brake , calipers , change , civic , compressing , crv , honda , pads , removing , replace , replacing , rotor , rotors
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Real racing rims?
rear brake drum to disc brake conversion?
Honda Fit HFP wheels
Brake Pad & Rotor DIY gone wrong!
Hubcentric Rings?
Nippon Wheels (Volk TE37 knockoffs)
More sick pictures of wheels I like....
Ahh yeah, new rims!
Invisible Tires
07 LX to Si wheels
Site Supporters
aluminum radiator
Honda car spoilers
