Go Back   Honda Civic Forum > GENERAL > Honda Civic Wheels, Tires, & Brakes
Honda Civic Wheels, Tires, & Brakes How underrated these parts can be when properly upgrading your Honda Civic to a true sports machine. Wheels, Tires, and Brakes for your Honda Civic can change the way your car looks, acceleration, and stopping distance.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-15-2009   #1 (permalink)
back2black
New Member
back2black is an unknown quantity at this point
Brake Rotor Suggestions
I have a wicked little pulsation in the brakes from good ole warped rotors, so I am gonna replace them. I would like to get a set of performance brake rotors. I have been looking at some of the options on Ebay, and man, there alot of them. Anyone have some real world experience based opinions on what to buy or not to buy? I have heard to pick drilled or slotted, not both. Anything/anyone specific to steer away from? I may go ahead and just get some oem replacements, but I would like to improve the braking on the car.
The other thing, how about some experience with ceramic pads? Are they low dust? Believe it or not, the car has the original hubcaps, and the paint is in very good shape on them, so I don't wanna ruin that buy scrubbing off brake dust all the time.
ROb
back2black is offline   Reply With Quote
Sponsored Links
Old 06-16-2009   #2 (permalink)
ronaldo9
Platinum Member
ronaldo9's Avatar
ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned
Send a message via AIM to ronaldo9
Re: Brake Rotor Suggestions
Brembo blanks or any ones will do from your local autozone. Stay away from ebay rotors. Ceramic pads are great you want low dust stick to OEM or hawk hps pads. I had EBC green stuff and they were dusty.
ronaldo9 is offline   Reply With Quote
Old 06-16-2009   #3 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Get slotted over drilled, drilled looks so ricey these days. And also, nobody talks about this, but the lighter your rotors are, the faster you will get up and go. If you find rotors that are heavier then stock, you'll be a little slower- more rotating mass.
TRIZ is offline   Reply With Quote
Old 06-16-2009   #4 (permalink)
back2black
New Member
Where are the Hawk EPS pads available? I would like to use Brembo parts, but they are wicked high in price aren't they? I will have to do more looking and see what I can find. The car isn't souped up or anything...but everyone can use better braking
ROb
Old 06-16-2009   #5 (permalink)
1.7EL_03
New Member
1.7EL_03 is an unknown quantity at this point
Just from my personal experience stay away from HAWK HPS + Brembo blanks.... the Brembo blanks will warp in less than a year! But don't get me wrong HAWK HPS pads are pretty damn good... just there a bit dusty.
I would recommend HAWK HPS and a performance rotor such as Extreme Stop. The rotors are slotted and cross drilled and you can pick the up at DEFCON ART for around $100 each. They run these rotors on the track and street with out any problems like warping or cracked pads!
1.7EL_03 is offline   Reply With Quote
Old 06-16-2009   #6 (permalink)
back2black
New Member
So the Hawk HPS pads are going to be dusty? That is something I definitely do not want. I get sick of scrubbing brake dust after awhile. I will prolly just end up going to Oreilly's and getting some Wagner Thermo Quiets. I have been very impressed with those pads as far as wear, low dust and quiet. Oh well, it is worth a try if I can find something that will work.
ROb
Old 06-17-2009   #7 (permalink)
TRIZ
TRIZ's Avatar
If you clean your wheels every week you;ll be fine. Just squirting them with water will get most of the dust off if you dont allow it to build up for months on end.
Old 06-17-2009   #8 (permalink)
back2black
New Member
Problem is that the civic is momma's car...Can't always get my hands on it when I want to for a bath.
ROb
Old 09-08-2009   #9 (permalink)
Atromos
New Member
Atromos is an unknown quantity at this point
I heard cheap cross-drilled rotors crack. Mostly everyone says slotted is good enough. Just get good pads and regular rotors, after reading about brake warp online, it seems like its mostly the pads fault, or improper lug nut torquing.
Atromos is offline   Reply With Quote
Tags
brake , brakes , braking , civic , diy , dust , hfp , honda , low , performance , portland , rotor , rotors , system , wagner
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Real racing rims?
rear brake drum to disc brake conversion?
Honda Fit HFP wheels
Brake Pad & Rotor DIY gone wrong!
Hubcentric Rings?
Nippon Wheels (Volk TE37 knockoffs)
More sick pictures of wheels I like....
Ahh yeah, new rims!
Invisible Tires
07 LX to Si wheels
Site Supporters
aluminum radiator
Honda car spoilers
