Go Back   Honda Civic Forum > GENERAL > Honda Civic Wheels, Tires, & Brakes
Honda Civic Wheels, Tires, & Brakes How underrated these parts can be when properly upgrading your Honda Civic to a true sports machine. Wheels, Tires, and Brakes for your Honda Civic can change the way your car looks, acceleration, and stopping distance.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-02-2009   #1 (permalink)
1badndn
New Member
1badndn is an unknown quantity at this point
right front brake stiking
Its a 91 honda civic lx. did a brake job on the front brakes. changed rotors, calipers, pads, mastercylinder is was leakingand brake booster it was bleeding down and leaking right brake hose and greased the slides. when i 1st drive it the brakes are great after about 5-7 miles the right front brake starts to drag and get worse. To remove this ad, register today for free or log in if already registered!
1badndn is offline   Reply With Quote
Sponsored Links
Old 01-03-2009   #2 (permalink)
1badndn
New Member
Re: right front brake stiking
I have the car on jack stands. brakes drag after a min or so. check calipers and hoses. then if i remove the vacumn line from the brake booster the brakes will release. ?????????
Old 01-03-2009   #3 (permalink)
1badndn
New Member
i think that the brake booster that is new, needs to be adjusted. anyone know how to adjust or check to see if it needs to be adjusted?
Old 01-03-2009   #4 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
Did you clean out all the old grease in the slidepins? Do they seem to be moving freely?
04 Honda Civic is offline   Reply With Quote
Old 01-04-2009   #5 (permalink)
1badndn
New Member
yep cleaned the slides and the have new hight temp grease, thanks. the pushrod for the brake booster need to be adjusted im just not for sure how to go about it
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Real racing rims?
rear brake drum to disc brake conversion?
Honda Fit HFP wheels
Brake Pad & Rotor DIY gone wrong!
Hubcentric Rings?
Nippon Wheels (Volk TE37 knockoffs)
More sick pictures of wheels I like....
Ahh yeah, new rims!
Invisible Tires
07 LX to Si wheels
Site Supporters
aluminum radiator
Honda car spoilers
