Go Back   Honda Civic Forum > GENERAL > Honda Civic Wheels, Tires, & Brakes
Reload this Page
Cryo or cross drilled?
Honda Civic Wheels, Tires, & Brakes How underrated these parts can be when properly upgrading your Honda Civic to a true sports machine. Wheels, Tires, and Brakes for your Honda Civic can change the way your car looks, acceleration, and stopping distance.
LinkBack Thread Tools
Old 09-22-2008   #1 (permalink)
2004GraphEx
New Member
2004GraphEx's Avatar
2004GraphEx is an unknown quantity at this point
I have been looking at brakes and not sure which ones to go with. Ne one tried the cryo treated discs? Do know that i am getting EBC red stuff pads, just not sure whether or not cross drilled or the cryo. I am a pretty spirited driver...if that helps at all.
2004GraphEx is offline   Reply With Quote
Sponsored Links
Old 09-22-2008   #2 (permalink)
manahoonie
manahoonie's Avatar
manahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questioned
Re: Cryo or cross drilled?
haven't heard of cryo treated discs.... gota a link?
manahoonie is offline   Reply With Quote
Old 09-23-2008   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
how about stock? its better than both of those combined. cryo treated is basically useless. and drilled means less surface area for the pad = worse braking.
gearbox is offline   Reply With Quote
Old 09-24-2008   #4 (permalink)
2004GraphEx
New Member
http://www.tirerack.com/brakes/brake...ar=&perfCode=S
those are the ones that i am looking at. just something to look nice behind the 16" ssr wheels that i am going to get.
Old 09-24-2008   #5 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questionedZzyzx should not be questionedZzyzx should not be questionedZzyzx should not be questionedZzyzx should not be questionedZzyzx should not be questionedZzyzx should not be questionedZzyzx should not be questionedZzyzx should not be questionedZzyzx should not be questionedZzyzx should not be questioned
Quote:
Friction is not subject to surface area, just pressure & the coefficient of friction between the two objects. so drilling has 0 effect on braking power.
For the Thread starter... what are your plans for this car? as drilling adds no benefit aside from looks, with the added issue of increasing the likelihood of cracking the rotors under heavy use. And cryo treatments haven't been definitively proven to do any thing...
Zzyzx is offline   Reply With Quote
Old 09-24-2008   #6 (permalink)
2004GraphEx
New Member
I am just looking to improve the exterior looks. Not looking for a drag car or nething like that. It is stock besides intake, header, cat, and exhaust. those are the only things getting done to the car as i have a 68 stang for the 'race' car feeling.
Old 09-25-2008   #7 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Well, then it really doesn't matter much. Drilling looks cool, but tends to reduce the service life of the rotor, where Cryo-treated rotors supposedly extend the life of the rotor, but just looks like a regular rotor.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Real racing rims?
rear brake drum to disc brake conversion?
Honda Fit HFP wheels
Ahh yeah, new rims!
Brake Pad & Rotor DIY gone wrong!
Hubcentric Rings?
Nippon Wheels (Volk TE37 knockoffs)
DIY - Make Your Own Customized Centercaps!
07 LX to Si wheels
More sick pictures of wheels I like....
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
