Go Back   Honda Civic Forum > GENERAL > Honda Civic Wheels, Tires, & Brakes
Honda Civic Wheels, Tires, & Brakes How underrated these parts can be when properly upgrading your Honda Civic to a true sports machine. Wheels, Tires, and Brakes for your Honda Civic can change the way your car looks, acceleration, and stopping distance.
Sponsored by: Tire Rack
Click Here
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-21-2008   #1 (permalink)
pigeon
Member
pigeon's Avatar
pigeon is an unknown quantity at this point
15x7.5" +40 wheels rubbing on 2005 Civic
Hey,
I have a customer who purchased a set of used wheels for his 2005 Civic. The wheels are 15x7.5" with a +40 offset.
Apparently during suspension compression the lower control arm is scraping against the inner side of the wheel. He tried testing it out with some spacers, however under hard cornering it is still scraping.
Does anyone know for sure, if there are any brand of rear LCA's available that are shaped in a way to eliminate the scraping? The customer lives over an hour away so I haven't been able to see it in person, so im just going off of what we discussed on the phone. Has anyone else run into this issue? How did you solve it?
Thanks!
pigeon is offline   Reply With Quote
Sponsored Links
Old 07-21-2008   #2 (permalink)
keepItJDM
New Member
keepItJDM's Avatar
keepItJDM is an unknown quantity at this point
Re: 15x7.5" +40 wheels rubbing on 2005 Civic
There are aftermarket rear LCA's available from Skunk2, Function7, and SPC performance that claim to correct the problem you described but from what I have heard from people that have bought they are just for looks
__________________
When in doubt, keep it oem.
keepItJDM is offline   Reply With Quote
Old 07-22-2008   #3 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
Quote:
That isnt what its rubbing on. Its rubbing on the A-arm. The only way you're going to be able to try and stop it is with a toe adjustment and/or harder bushings in the knuckle so that it doesnt flex as much under load. Had this issue with a set of 16x8s. Its in the geometry, the front side of the wheel makes contact under cornering. If the ride height of the car is adjustable and the car can be raised, try that, it'll bring the A-arm higher in the wheel.
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Real racing rims?
rear brake drum to disc brake conversion?
Honda Fit HFP wheels
Brake Pad & Rotor DIY gone wrong!
Hubcentric Rings?
Nippon Wheels (Volk TE37 knockoffs)
More sick pictures of wheels I like....
Invisible Tires
Tire Size
Ahh yeah, new rims!
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
