Go Back   Honda Civic Forum > GENERAL > Honda Civic Wheels, Tires, & Brakes
Honda Civic Wheels, Tires, & Brakes How underrated these parts can be when properly upgrading your Honda Civic to a true sports machine. Wheels, Tires, and Brakes for your Honda Civic can change the way your car looks, acceleration, and stopping distance.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-23-2008   #16 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Re: Real racing rims?
So answer me this... a 14 inch rim and tire, will that weigh less then a 16 inch rim and tire? Common sense would say the 14 incher would be lighter with a tire, because rubber is ligther then metal.
anyone have any info/data on what real life tradeoffs would be as far as weight and speed are with increasing rim size?
TRIZ is offline   Reply With Quote
Sponsored Links
Old 07-23-2008   #17 (permalink)
Eyger
A long winded 7th genr
Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned
Send a message via AIM to Eyger
That's weird I didn't even notice that this was a second page to your original post.
I accidentally posted. I donno man.
just a random thought, what do you think would happen if you put helium in your tires? Ha ha, that would be weird right. Do you think it would reduce the weight of the wheel and tire combo?
Edited:
After searching the web for this idea turns out:
This was a stupid idea of course. Anyways, Guess I'll just stick with nitrogen
Eyger is offline   Reply With Quote
Old 07-24-2008   #18 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
Edited:
Helium.... for starters the tire would lose Psi at a much greater rate. (Helium, He2, is a very small molecule)
Tires already loose Psi over time as the oxygen & argon slowly leak through the rubber.
Nitrogen would be a better choice here, as its natural state is a much larger molecule and therefore less seeps through the tire. Which is the prime reason why some tire shops offer it.
Other wise, it wouldn't matter, as I know you were thinking that Helium is lighter then "air" so wouldn't that make the tire lighter.... Problem here is that you are putting the gas under pressure, a good deal of pressure. which means a higher concentration of He2 because its so small, which means more weight. (You don't see tanks of He floating away do you?)
__________________
Las Vegas SCCA
Autocross: Because Life is more fun on three wheels......
"I know Solo only comes one minute at a time, but what an intense, non-stop, fast-forward car control exercise minute it is. Sure, the velocity is higher in road racing, but inside the car it is slow-motion in comparison. In Solo, the turns come like machine-gun rounds. "
Randy Pobst
Zzyzx is offline   Reply With Quote
Old 07-24-2008   #19 (permalink)
emjay
Super Member
emjay is a jewel in the rough emjay is a jewel in the rough emjay is a jewel in the rough emjay is a jewel in the rough
5zigen fn01rc .. the ones i have are pretty light ...i think bout 12 lbs a wheel
__________________
boosted 1.7eL -- whp: classified
emjay is offline   Reply With Quote
Old 07-24-2008   #20 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
the 14" setup could weigh less, or it may weigh about the same as the 16" setup.
The important part here is that the main mass, the wheel its self is closer to the center of rotation, which reduces that wheels rotational Inertia
The basic formula for estimating Rotational Inertia of a hoop goes like this.. I=m(r^2)
I = Inertia
M= Mass (weight)
r = Radius
So, compiring a 14" that weighs say 15lbs Vs a 16" Wheel that weighs 15lbs
15lbs = 6.8kg
14" = 35.6cm
16" = 40.6cm
so for the 14"
I = 6.8(17.8^2)
I = 6.8*316.84
I = 2154.512
for the 16"
I = 6.8(20.3^2)
I = 6.8*412.09
I = 2802.212
A 24% difference in rotational Inertia from just the wheel its self!
Now, as far as the upside of larger wheels. Well, most street tires have fairly flexible sidewalls which means the tire will distort more while under cornering loads giving you less overall traction then you could have had. Replacing this flexible rubber with relatively inflexible metal means the tire flexes less and you have the potential to make more traction.
So larger wheels will hinder acceleration & braking, but can help with cornering... if you are running tires with soft sidewalls.
__________________
Las Vegas SCCA
Randy Pobst
Old 12-07-2008   #21 (permalink)
00telehit
New Member
00telehit is an unknown quantity at this point
Well i recommend you Advan wheels, i have Advan RS gold wheels , really light, used in japan, for circuit racing, made in 1oo% aluminum.
Advan RS GOld
or you can go with Advan RGll
or Advan TCll
[IMG]http://i247.photobucket.com/albums/gg123/andresbmw21/wheel_01.jpg
[/IMG]
and here are some pictures of how they look on the cars.
00telehit is offline   Reply With Quote
Old 12-08-2008   #22 (permalink)
Fox04coupe
Senior Member
Fox04coupe's Avatar
Fox04coupe is a glorious beacon of light Fox04coupe is a glorious beacon of light Fox04coupe is a glorious beacon of light Fox04coupe is a glorious beacon of light Fox04coupe is a glorious beacon of light
that car would be way nicer without the wing... lift off
__________________
http://www.civicforums.com/forums/46...ml#post4143971
ALL YOU NEED TO KNOW ABOUT GAUGE SWAPS
Fox04coupe is offline   Reply With Quote
Old 12-10-2008   #23 (permalink)
2Slow4U
New Member
2Slow4U's Avatar
2Slow4U is an unknown quantity at this point
i have centerline auto drags in 14", very light, they are the old school solid wheel...
__________________
Just how dumb are you? Exactly too stupid to ever figure it out, but blessed with enough intelligence to always wonder about it....
Ive been down the track more times than you have driven to work...
2Slow4U is offline   Reply With Quote
Tags
14 , civic , craigslist , forum , honda , keizer , light , lug , og , raceing , racing , rim , rims , weight , wheels
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Real racing rims?
rear brake drum to disc brake conversion?
Honda Fit HFP wheels
Brake Pad & Rotor DIY gone wrong!
Hubcentric Rings?
Nippon Wheels (Volk TE37 knockoffs)
More sick pictures of wheels I like....
Ahh yeah, new rims!
Invisible Tires
07 LX to Si wheels
Site Supporters
aluminum radiator
Honda car spoilers
