OK here goes
1. unmount tires
2. use aircraft stripper, paint stripper, etc. to get them down to bare metal as or as close as possible
3. light sanding
4. coat of primer
5. sand with high grain (1200 works)
6. another coat of primer
7. wet sand with high grain (1200-1500)
8. wash
9. clean with alcohol...rubbing alcohol works
10. paint
rememember when painting, keep can approx 6-9 inches from the wheel and start spraying off the wheel...youll thank me. use light coats go over it once lightly, then let it dry, repeat...do this about 3-5 times until it is consistent color all over the wheel let it dry between 30 minutes and 2 hours between coats...see back of your can for details
use wheel paint. its good stuff, i get mine at advance auto parts for about 4 a can.
clearcoat, i do this by request (yes i paint wheels for people in my spare time), but there are solid ones, and ones with flake in them that i think look stupid but some like them...clearcoat spray it the same as paint but DONT sand it. clearcoat dries a bit quicker than paint the stuff I use dries in about 10-20 minutes but I let it sit for approx 30 just to be safe. any other questions, PM me or post em here...here is some of my work
my ICW wheels were in need of a refinish..finished product. unfortunately the incompetent assholes at the shop fuckewd the lip when they put the tires back on so the owner said the service was free
And my steelies..i didnt care much about them and didnt unmount the tires either. show your friends a new card trick
Prep is the MOST important part of this all. Im in philly if you are close to here I can do em with or for you. LMK...
