Go Back   Honda Civic Forum > GENERAL > Honda Civic Wheels, Tires, & Brakes
Reload this Page
Warped already... bummer.
Honda Civic Wheels, Tires, & Brakes How underrated these parts can be when properly upgrading your Honda Civic to a true sports machine. Wheels, Tires, and Brakes for your Honda Civic can change the way your car looks, acceleration, and stopping distance.
LinkBack Thread Tools
Old 04-23-2007   #16 (permalink)
04civic07
Living Life Turn After Turn
04civic07's Avatar
04civic07 is an unknown quantity at this point
Re: Warped already... bummer.
UPGRADE! to the DC2R.... bigger rotors... better cooling, better cooling.... lasting longer!, but yeah 40k is about right to change.
04civic07 is offline   Reply With Quote
Old 05-06-2007   #17 (permalink)
LT2004ever
I wil fix vBPlaza today
LT2004ever's Avatar
Quote:
Originally Posted by robbclark1 View Post
Cheap rotors from pepboys/autozone/etc - $30
Axxis ultimates - $60
Total = $90
these would be a way better purchase than the brembo blanks and hawk pads?
LT2004ever is offline   Reply With Quote
Old 05-17-2007   #18 (permalink)
ryox82
Super Member
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Im guessing if it was a daily driver, I got mine from auto zone, 40ish for both....and that was the expensive set. Then again I dont race in any way, just wanted a standard replacement. Also im rockin the steelies with the oem cover :-P Doesnt have to look "clean"
ryox82 is offline   Reply With Quote
Old 05-25-2007   #19 (permalink)
DaMadScientist
Pwning Noobs 24/7
DaMadScientist's Avatar
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
you might also check that if the lugnuts are two tight, or were not tightened in criss-cross order they could of warped your rotors as well
DaMadScientist is offline   Reply With Quote
Old 05-25-2007   #20 (permalink)
mugenman
"mmmBAHHHH" - vtec y0
mugenman's Avatar
mugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questioned
if your strapped for cash just get some duralast golds from autozone but if cash isnt an issue id go with the same set up you had.
mugenman is offline   Reply With Quote
Old 06-01-2007   #21 (permalink)
rice4lyfe
Super Member
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
how do you tighten your rotors? To get miniman warpage on rotors, always tighten with a criss-cross patter USING A TORQUE WRENCH
rice4lyfe is offline   Reply With Quote
Old 12-19-2007   #22 (permalink)
WgnrNick
Senior Member
WgnrNick's Avatar
WgnrNick will become famous soon enoughWgnrNick will become famous soon enough
From the way you make your driving sound, 40k is actually pretty good. Try down shifting some more and you should get a longer life out of them.
Wagner
WgnrNick is offline   Reply With Quote
Old 08-16-2008   #23 (permalink)
babzog
New Member
babzog is an unknown quantity at this point
Quote:
Clutch job: around $800 and a day or two in the shop.
Brake job (all wheels): around $260 and an evening / afternoon of my time.
For the money, I rarely, if ever, downshift. I let my brakes do the slowing.
babzog is offline   Reply With Quote
Old 08-16-2008   #24 (permalink)
tuningmycivic
Ultimate Member
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
or you could just get off the gas sooner...and brake gradually instead of stoplight-dragging from corner to corner. i just passed 80k on my car with 60 of them on my Hawk HP pads and powerslot rotors. I'd guess I still have another 20k or so in them driving normally. and no signs of warping.
tuningmycivic is offline   Reply With Quote
Old 08-16-2008   #25 (permalink)
babzog
New Member
^^^ That works too!
Old 08-18-2008   #26 (permalink)
manahoonie
manahoonie's Avatar
manahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questioned
or we can see the dates between posts...
last post before this was brought back yesterday: 12 19 2007
manahoonie is offline   Reply With Quote
Old 08-19-2008   #27 (permalink)
babzog
New Member
Yeah... I was replying to a post that came up in a search and never thought to check the date. What can I say.
Old 09-03-2008   #28 (permalink)
DarkFlame
New Member
DarkFlame is an unknown quantity at this point
I've got 98k original miles on my '98 LX. I've had the brake rotors resurfaced twice and replaced once (warping all 3 times). They did it under warrantee because I've never had a vehicle have this kind of trouble with the brakes. Tires have only been changed professionally, so if they overtightened them, they screwed it up, not me. Admittedly, I'm not easy on the brakes, but I felt that was ridiculous. Since I started riding the motorcycle, I've only put about 4k miles each year on the Civic (& wife drives Grand Caravan). So, it's not getting nearly the wear & tear that it got the first 6 years we owned the car.
I'm looking to replace the rotors with something a LOT more heavy-duty than the flimsy stockers. I want to keep the car another 10 years & do some other upgrades to it, also. And, I'm "not bad" with a wrench - I've rebuilt 4 engines, done numerous brake jobs, installed dual carbs on a VW & kept them synced, etc. So, replacing brake pads, rotors, & cylinders is about an afternoon's work for me.
Brands & models will be most appreciated on the following:
  • What are the best & most heavy duty rotors available?
  • Do I need to replace the stock cylinders or will they work with the OEMs?
  • What are comparably heavy duty pads?
This will be my first mod on the car, and the first work I've done on it myself (other than an occasional oil change, but most of those have been done professionally). But, I've owned 9 other cars/trucks & did all the work on most of them, not to mention that I'm on my 3rd motorcycle & have done extensive work on this one. So, I'm not afraid of a tool nor getting dirty.
I appreciate the assistance,
David
"I've got a torque wrench & I'm not afraid to use it!"
DarkFlame is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Real racing rims?
rear brake drum to disc brake conversion?
Honda Fit HFP wheels
Ahh yeah, new rims!
Brake Pad & Rotor DIY gone wrong!
Hubcentric Rings?
Nippon Wheels (Volk TE37 knockoffs)
DIY - Make Your Own Customized Centercaps!
07 LX to Si wheels
More sick pictures of wheels I like....
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
