Honda Civic Wheels, Tires, & BrakesHow underrated these parts can be when properly upgrading your Honda Civic to a true sports machine. Wheels, Tires, and Brakes for your Honda Civic can change the way your car looks, acceleration, and stopping distance.
Welcome to civicforums.com!
Welcome to civicforums.com.
ok so i got everything off...now the only thing that is pissin me off is the two screws holdin the rotor on. i cannot get it out. i been at this for an hour and a half already. also i spray a whole lot of wd-40 too. plzz is there any trick. i tried bangin one of the screws out and it didnt even move 1/8 of a circle.
Sponsored Links
i assume you're using a philips scredriver...find a flat tip that's just wide enough to fit the screw, put a set of vise grips on it and turn it that way. even better if you have a ratchet and some screwdriver bits, you can put a little more torque on it without worring so much about it slipping cause you can really lean on it better. good luck man, i went through the same problem when i swapped out my rotors.
Another trick for getting those stubborn screws off, if you have a small drill bit, drill a small shallow hole in the center of the screw, if you get some of the metal out of the center, the bit fits better in there. Or if you have a dremel type tool, you can cut a flat slit in the head of the screw to fit a larger flathead in there. Or you can just curse at it until it cowers in fear. I've done that before, ha ha, jk. I was working on an exhaust nut that would'nt come off of this Mazda, so I just cursed at it and cranked a vice grip on it, it broke the vice grip. So me and my father had to get one of those stripped nut ratchet head kits to get it off. It was a BEEACH! nuts and bolts are a pain is the ass, but hold the whole car together.
